2016-09-13, 17:23
2016-09-13, 20:18
You need to use the Jarvis branch. The master branch in nearly all repositories of Kodi addons is for the current version, which in this case is Krypton (17).
2016-09-14, 20:14
(2016-09-13, 20:18)rpcameron Wrote: [ -> ]You need to use the Jarvis branch. The master branch in nearly all repositories of Kodi addons is for the current version, which in this case is Krypton (17).
Thank you so much for taking the time to reply.
How do I go about switching the repository branch?
2016-09-14, 20:40
If you're building yourself and using git: If you have already cloned the repo:
$ git clone -b Jarvis https://github.com/kodi-pvr/pvr.iptvsimple
$ git checkout Jarvis
2016-09-15, 18:36
(2016-09-14, 20:40)rpcameron Wrote: [ -> ]If you're building yourself and using git:If you have already cloned the repo:Code:$ git clone -b Jarvis https://github.com/kodi-pvr/pvr.iptvsimple
Code:$ git checkout Jarvis
Thanks for that hugely appreciated! Ill give it a go as soon as i'm home.
I take it doing this will combat the "AN UNKNOWN ERROR HAS OCCURRED CAN'T LOAD DLL" message i get when trying to run the plugin.
The version of the plugin i'm getting this from is 2.4.1 i did briefly try 2.4.3 but i got a dependencies problem.
