2016-09-14, 02:24
How can I change the spacing between the widget posters as I want to make the closer together I've looked through both the template.xml and includeshomewidgets.xml but can't seem to find it.
(2016-09-14, 02:24)LeeH1988 Wrote: [ -> ]How can I change the spacing between the widget posters as I want to make the closer together I've looked through both the template.xml and includeshomewidgets.xml but can't seem to find it.If i remember correct you need edit the
(2018-03-31, 23:48)norien Wrote: [ -> ]Where abouts would I go to change this?Edit in IncludesHomeWidgets.xml
xml:<itemlayout height="380" width="261"> <!-- given space / FORM -->
<control type="group">
<width>250</width> <!--used space / FORM -->
<height>370</height> <!-- used space / FORM -->
<focusedlayout height="380" width="261" condition="!Control.HasFocus($PARAM[widgetid])"> <!-- given space / FORM when on focus-->
<height>370</height> <!--used space / FORM -->
