I recently switched from guest/read-only access to protected SMB shares and PseudoTV no longer works, it just hangs when trying to load my first channel.
Here's Kodi's log:
http://pastebin.com/uPqBNW2M
I couldn't find a PseudoTV log, even though I enabled debug logging.
Sent from my AOSP on dragon
(2016-09-17, 00:22)brando56894 Wrote: [ -> ]I recently switched from guest/read-only access to protected SMB shares and PseudoTV no longer works, it just hangs when trying to load my first channel.
Here's Kodi's log: http://pastebin.com/uPqBNW2M
if you protected paths you need to make sure that both Kodi and PTVL have access to those new paths.... for example path "user:
[email protected]\cache"
Same goes for your sources.xml paths and its also recommend you rescrape all your media.
It looks like my problem was a messed up config, I wiped out my kodi profile and started over and now everything seems fine.
