Full Version: Set higher default brightness?
what do I have to add to advancedsettings.xml to set a brightness of 56% (instead of 50%) for all videos?
I can't see anything
http://kodi.wiki/view/advancedsettings.xml#epg
If you play a video, then go to the Video osd you might be able to set it there
(2016-09-18, 17:18)bubblegum57 Wrote: [ -> ]If you play a video, then go to the Video osd you might be able to set it there
That's what I'm doing at the moment, but I have to do it _every_ time - that's something I wanted to avoid.
(2016-09-18, 17:28)Elmi79 Wrote: [ -> ]
Are you then setting as default for all movies?
Do not know if it will work on linux like on windows...
-play a video
-open video osd settings
-set your brightness
-scroll down
-use "apply to all"
-close the video osd
It should apply your brightness to all your video
