Just Installed kodi from Windows Store, when launched it gives me BSOD (stop_kernel_security_check_failure) and reboots computer :/
Store description says it is version 17beta2 but version i have is 16.9.803.0
Any clue on what's wrong ?
There's a few issues atm with the windows download install. Patience, a proper debug log posted to a public paste-bin (pastebin.com) and linked back to this thread would help a lot.
Log file/Advanced (wiki) section 1.2 Turn on debugging using a file (advancedsettings.xml) is probably the most practical way to do this on a first start crash. A download from here would probably be more successful, and note my sig for a fresh start.
Please help us and Microsoft getting this fixed by doing the following:
Getting a Watson bucket from the reliability monitor
1. Click "Start" and type in "View Reliability History"
2. In the graph at the top, select the day that the blue screen happened
3. Look down in the list and select the right event (not sure exactly what it will say, but I suspect it will be a critical event. You should be able to tell by the Date whether it’s the right one)
4. Right click on that event, and choose View Technical Details
5. Please give us the Bucket ID text at the end of the list that is between the ( )
Thank you
