Full Version: Public Estuary GitHub repository
Pages: 1 2
If people want to contribute to Estuary, here is a public branch which i intend to keep in sync with the skin from our main kodi repo.
https://github.com/phil65/skin.estuary
So if you feel like putting up a PR or if you are interested in the past development of the skin, then this is the place to go. Wink
any chance we could get a test build of the new skin design? Smile or ETA on when it will sync with nightlys. Smile thx
soon :-)
(2016-11-22, 00:36)mazey Wrote: [ -> ]any chance we could get a test build of the new skin design? Smile or ETA on when it will sync with nightlys. Smile thx
Here : https://github.com/phil65/skin.estuary
(2016-11-22, 01:47)Guilouz Wrote: [ -> ]
yeah compiling for android is a lot harder then it looks Sad
You don't need to compile a skin, simply download the zip from github.
(2016-11-22, 02:38)jjd-uk Wrote: [ -> ]You don't need to compile a skin, simply download the zip from github.
ohh Smile lol now i feel even more noob, thanks man Smile
Forgive my ignorance, but when I try to install the copy that I downloaded from GitHub using Kodi's "install from zip file", it errors out. Is this due to Estuary being the default skin with beta 5? Is there some other way to install the copy from GitHub?
(2016-11-22, 22:50)spencers Wrote: [ -> ]Forgive my ignorance, but when I try to install the copy that I downloaded from GitHub using Kodi's "install from zip file", it errors out. Is this due to Estuary being the default skin with beta 5? Is there some other way to install the copy from GitHub?
try shutting kodi down then reopening and do it. if that doesnt work upgrade to the latest nightly build.
If you can't wait for the update PR to be merged....
- Download from Github
- Extract the zip and rename folder to "skin.estuary" (remove the .master)
- If using windows go to C:\Program Files (x86)\Kodi\addons
- Rename "skin.estuary" to "skin.estuary.old"
- Copy the skin.estuary folder you downloaded earlier to C:\Program Files (x86)\Kodi\addons
Initial impressions are it looks great, maybe a bit dark towards the top.
Much improved though, love new new slightly rounded buttons. Nice work!
Still no custom main menu's via nodes yet...?
Thanks, docwra. I'm running LibreElec and the location where estuary resides (/usr/share/kodi/addons) is read-only and cannot be renamed.
I found the tutorial below and it worked for me. One additional note: I had to go into the addons browser and enable the new skin to get it to show up in the skins list.
182558 (thread)
Skin looks great. I noticed right off the bat that it really uses the entire width and height of the screen.
(2016-11-24, 18:52)spencers Wrote: [ -> ]Thanks, docwra. I'm running LibreElec and the location where estuary resides (/usr/share/kodi/addons) is read-only and I cannot rename even when I SSH as root.
I have it on a box running LibreElec and i just installed it from the zip download from github (rename the folder inside the zip from "skin.estuary-master" to "skin.estuary" first) and it runs with no problems, to update i just drag and drop the files from git and overwrite using filezilla
small feature, log off button, pull request submitted
https://github.com/phil65/skin.estuary/pull/195
(2016-09-22, 01:20)phil65 Wrote: [ -> ]If people want to contribute to Estuary, here is a public branch which i intend to keep in sync with the skin from our main kodi repo.
Problem with install from zip xbmc gue version can.t install from zip kodi 17.4
Pages: 1 2
