Full Version: Playback- Problems with some videos: skip, fast forward etc. didn't works correc
First at all:
- Hoping my english is good enough
- I'm not using "advancedsettings.xml"
- It makes no difference if I'm using the "on Screen keyboard" or the "remote control"
- "Play next video automatically" is deactivated
What I'm using:
- VU+ Ultimo with internal harddisc for recording. After recording I'm moving the files to my NAS (Synology DS213j, DSM 6)
- FireTV (Version 1) connected via Gigabit with my NAS
- I'm using on my FireTV SPMC Version 16.4.2. With 15.0 I have the same issue.
Playing HD-Videos are working fine. Pause/ Resume, skip-function, fast forwarding are working correctly ==> I havn't a network-problem
With some SD- Videos I have the issue. What I've found out: I have cutted (deleted the advertising) the videos this way (ok; I havn't checked all my videos):
- demultiplexed the TS-file with ProjectX
- cutted and multiplexed with cuttermaran
- converted the mpeg- file to a TS-file with ProjectX (Yes, I have activated the option "Ensure that each sequence has a GOP header")
If I'm playing back the video-files via Ethernet with p.a. VLC on my PC or on my "VU+ Ultimo" I can use the similar functions without problems (Pause/ resume are working, skip works,...)
Hoping someone can help me.
15:45:07 T:18446744072494383336  NOTICE: special://profile/ is mapped to: special://masterprofile/
15:45:07 T:18446744072494383336  NOTICE: -----------------------------------------------------------------------
15:45:07 T:18446744072494383336  NOTICE: Starting SPMC (16.4-2 Git:2016-08-15-46f733d-dirty). Platform: Android ARM 32-bit
15:45:07 T:18446744072494383336  NOTICE: Using Release SPMC x32 build
15:45:07 T:18446744072494383336  NOTICE: SPMC compiled Aug 15 2016 by GCC 4.8.0 for Android ARM 32-bit API level 17 (API level 17)
15:45:07 T:18446744072494383336  NOTICE: Running on Amazon AFTB with Android 5.1.1 API level 22, kernel: Linux ARM 32-bit version 3.4.0-perf-gd7006e5
15:45:07 T:18446744072494383336  NOTICE: FFmpeg version: 2.8.6-kodi-2.8.6-Jarvis-16.0-spmc
15:45:07 T:18446744072494383336  NOTICE: Host CPU: ARMv7 Processor rev 0 (v7l), 4 cores available
15:45:07 T:18446744072494383336  NOTICE: Product: bueller, Device: bueller, Board: MSM8960 - Manufacturer: Amazon, Brand: Amazon, Model: AFTB, Hardware: qcom
15:45:07 T:18446744072494383336  NOTICE: External storage path = /storage/emulated/0; status = ok
15:45:07 T:18446744072494383336  NOTICE: HasTouchScreen = no
15:45:07 T:18446744072494383336  NOTICE: ARM Features: Neon enabled
15:45:07 T:18446744072494383336  NOTICE: special://xbmc/ is mapped to: /data/data/com.semperpax.spmc16/cache/apk/assets
15:45:07 T:18446744072494383336  NOTICE: special://xbmcbin/ is mapped to: /data/data/com.semperpax.spmc16/cache/apk/assets
15:45:07 T:18446744072494383336  NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc/userdata
15:45:07 T:18446744072494383336  NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc
15:45:07 T:18446744072494383336  NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc/temp
15:45:07 T:18446744072494383336  NOTICE: The executable running is:
15:45:07 T:18446744072494383336  NOTICE: Local hostname: localhost
15:45:07 T:18446744072494383336  NOTICE: Log File is located: /storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc/temp/spmc.log
15:45:07 T:18446744072494383336  NOTICE: load settings...
15:45:08 T:18446744072494383336   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
15:45:08 T:18446744072494383336 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
15:45:08 T:18446744072494383336   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
15:45:08 T:18446744072494383336   DEBUG: AESinkAUDIOTRACK - 32000 supported
15:45:08 T:18446744072494383336   DEBUG: AESinkAUDIOTRACK - 44100 supported
15:45:08 T:18446744072494383336   DEBUG: AESinkAUDIOTRACK - 48000 supported
15:45:08 T:18446744072494383336   DEBUG: AESinkAUDIOTRACK - 96000 supported
15:45:08 T:18446744072494383336  NOTICE: Found 1 Lists of Devices
15:45:08 T:18446744072494383336  NOTICE: Enumerated AUDIOTRACK devices:
15:45:08 T:18446744072494383336  NOTICE:     Device 1
15:45:08 T:18446744072494383336  NOTICE:         m_deviceName      : AudioTrackPCM
15:45:08 T:18446744072494383336  NOTICE:         m_displayName     : Android
15:45:08 T:18446744072494383336  NOTICE:         m_displayNameExtra: PCM
15:45:08 T:18446744072494383336  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
15:45:08 T:18446744072494383336  NOTICE:         m_channels        : FL,FR,FC,LFE,BL,BR,SL,SR
15:45:08 T:18446744072494383336  NOTICE:         m_sampleRates     : 32000,44100,48000,96000
15:45:08 T:18446744072494383336  NOTICE:         m_dataFormats     : AE_FMT_S16LE,AE_FMT_FLOAT
15:45:08 T:18446744072494383336  NOTICE:     Device 2
15:45:08 T:18446744072494383336  NOTICE:         m_deviceName      : AudioTrackPT
15:45:08 T:18446744072494383336  NOTICE:         m_displayNameExtra: IEC Passthrough
15:45:08 T:18446744072494383336  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
15:45:08 T:18446744072494383336  NOTICE:         m_dataFormats     : AE_FMT_AC3,AE_FMT_DTS
15:45:08 T:18446744072494383336  NOTICE:     Device 3
15:45:08 T:18446744072494383336  NOTICE:         m_deviceName      : AudioTrackPTRAW
15:45:08 T:18446744072494383336  NOTICE:         m_displayNameExtra: RAW Passthrough
15:45:08 T:18446744072494383336  NOTICE:         m_dataFormats     : AE_FMT_AC3_RAW,AE_FMT_EAC3_RAW,AE_FMT_DTS
15:45:08 T:18446744072494383336   DEBUG: CSkinSettings: no <skinsettings> tag found
15:45:08 T:18446744072494383336  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
15:45:08 T:18446744072494383336  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:45:08 T:18446744072494383336  NOTICE: Default DVD Player: dvdplayer
15:45:08 T:18446744072494383336  NOTICE: Default Video Player: dvdplayer
15:45:08 T:18446744072494383336  NOTICE: Default Audio Player: paplayer
15:45:08 T:18446744072494383336  NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:45:08 T:18446744072494383336  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
15:45:08 T:18446744072494383336  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
15:45:08 T:18446744072494383336  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:45:08 T:18446744072494383336  NOTICE: Loaded playercorefactory configuration
15:45:08 T:18446744072494383336  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:45:08 T:18446744072494383336  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:45:08 T:18446744072494383336  NOTICE: Running database version Addons20
15:45:08 T:18446744072494383336  NOTICE: ADDONS: Using repository repository.xbmc.org
15:45:08 T:18446744072494383336  NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: android
15:45:08 T:18446744072494383336  NOTICE: CEGLNativeTypeAndroid: Current resolution: 1920x1080 @ 60.000000 - Full Screen
15:45:08 T:18446744072494383336  NOTICE: Previous line repeats 1 times.
15:45:08 T:18446744072494383336  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
15:45:08 T:18446744072494383336  NOTICE: Found ([email protected]) at 16, setting to RES_DESKTOP at 16
15:45:08 T:18446744072494383336  NOTICE: Checking resolution 16
15:45:08 T:18446744072494383336  NOTICE: GL_VENDOR = Qualcomm
15:45:08 T:18446744072494383336  NOTICE: GL_RENDERER = Adreno (TM) 320
15:45:08 T:18446744072494383336  NOTICE: GL_VERSION = OpenGL ES 3.0 [email protected] [email protected] ([email protected])
15:45:08 T:18446744072494383336  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
15:45:08 T:18446744072494383336  NOTICE: GL_EXTENSIONS = GL_AMD_compressed_ATC_texture GL_AMD_performance_monitor GL_AMD_program_binary_Z400 GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_discard_framebuffer GL_EXT_robustness GL_EXT_texture_format_BGRA8888 GL_EXT_texture_type_2_10_10_10_REV GL_NV_fence GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth_texture GL_OES_depth24 GL_OES_EGL_image GL_OES_EGL_sync GL_OES_EGL_image_external GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_fragment_precision_high GL_OES_get_program_binary GL_OES_packed_depth_stencil GL_OES_depth_texture_cube_map GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_array_object GL_QCOM_alpha_test GL_QCOM_binning_control GL_QCOM_driver_control GL_QCOM_perfmon_global_mode GL_QCOM_extended_get GL_QCOM_extended_get2 GL_QCOM_tiled_rendering GL_QCOM_writeonly_rendering GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_texture_sRGB_decode GL_EXT_texture_filter_anisotropic GL_EXT_multisampled_render_to_texture GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_disjoint_timer_query
15:45:08 T:18446744072494383336   ERROR: static int SysfsUtils::SetInt(const string&, int): error opening /sys/class/graphics/fb0/format_3d
15:45:08 T:18446744072494383336  NOTICE: Running database version ViewModes6
15:45:08 T:18446744072494383336  NOTICE: Running database version Textures13
15:45:08 T:18446744072494383336  NOTICE: Running database version MyMusic56
15:45:08 T:18446744072494383336  NOTICE: Running database version MyVideos99
15:45:08 T:18446744072494383336  NOTICE: Running database version TV29
15:45:08 T:18446744072494383336  NOTICE: Running database version Epg11
15:45:09 T:18446744072494383336 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
15:45:09 T:18446744072494383336  NOTICE: ActiveAE DSP - starting
15:45:09 T:18446744072494383336  NOTICE: initialize done
15:45:09 T:18446744072494383336  NOTICE: Running the application...
15:45:09 T:18446744072494383336  NOTICE: starting zeroconf publishing
15:45:09 T:18446744072494383336  NOTICE: WebServer: Started the webserver
15:45:09 T:18446744072494383336  NOTICE: starting upnp client
15:45:09 T:18446744072494383336  NOTICE: CEGLNativeTypeAndroid: Current resolution: 1920x1080 @ 60.000000 - Full Screen
15:45:09 T:18446744072502688008  NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
15:45:09 T:18446744072502688008  NOTICE: UDP: Listening on port 9777
15:45:09 T:18446744072494383336  NOTICE: GL_VENDOR = Qualcomm
15:45:09 T:18446744072494383336  NOTICE: GL_RENDERER = Adreno (TM) 320
15:45:09 T:18446744072494383336  NOTICE: GL_VERSION = OpenGL ES 3.0 [email protected] [email protected] ([email protected])
15:45:09 T:18446744072494383336  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
15:45:09 T:18446744072494383336  NOTICE: GL_EXTENSIONS = GL_AMD_compressed_ATC_texture GL_AMD_performance_monitor GL_AMD_program_binary_Z400 GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_discard_framebuffer GL_EXT_robustness GL_EXT_texture_format_BGRA8888 GL_EXT_texture_type_2_10_10_10_REV GL_NV_fence GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth_texture GL_OES_depth24 GL_OES_EGL_image GL_OES_EGL_sync GL_OES_EGL_image_external GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_fragment_precision_high GL_OES_get_program_binary GL_OES_packed_depth_stencil GL_OES_depth_texture_cube_map GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_array_object GL_QCOM_alpha_test GL_QCOM_binning_control GL_QCOM_driver_control GL_QCOM_perfmon_global_mode GL_QCOM_extended_get GL_QCOM_extended_get2 GL_QCOM_tiled_rendering GL_QCOM_writeonly_rendering GL_EXT_sRGB GL_EXT_sRGB_write_control GL_EXT_texture_sRGB_decode GL_EXT_texture_filter_anisotropic GL_EXT_multisampled_render_to_texture GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_disjoint_timer_query
15:45:25 T:18446744072494383336  NOTICE: DVDPlayer: Opening: smb://192.168.2.10/VU_Ultimo_Backup/(T)Raumschiff Surprise - Periode 1.ts
15:45:25 T:18446744072494383336 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
15:45:25 T:18446744072511986768  NOTICE: Creating InputStream
15:45:26 T:18446744072511986768  NOTICE: Creating Demuxer
15:45:26 T:18446744072511986768  NOTICE: Opening stream: 0 source: 256
15:45:26 T:18446744072511986768  NOTICE: Creating video codec with codec id: 2
15:45:26 T:18446744072511986768  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
15:45:26 T:18446744072511986768  NOTICE: Creating video thread
15:45:26 T:18446744072511986768  NOTICE: Opening stream: 2 source: 256
15:45:26 T:18446744072511986768  NOTICE: Finding audio codec for: 86019
15:45:26 T:18446744072508090608  NOTICE: running thread: video_thread
15:45:26 T:18446744072511986768  NOTICE: Creating audio thread
15:45:26 T:18446744072511986768  NOTICE: Opening stream: 0 source: 1024
15:45:26 T:18446744072503032328  NOTICE: running thread: CDVDPlayerAudio::Process()
15:45:26 T:18446744072511986768   ERROR: bool CDVDPlayerSubtitle::OpenStream(CDVDStreamInfo&, std::string&) - Unable to create subtitle parser
15:45:26 T:18446744072511986768  NOTICE: Opening stream: 0 source: 1025
15:45:27 T:18446744072511986768   ERROR: bool CEdl::ReadComskip(const string&, float) - Invalid Comskip file: smb://192.168.2.10/VU_Ultimo_Backup/(T)Raumschiff Surprise - Periode 1.txt. Error reading line 1 - expected 'FILE PROCESSING COMPLETE' at start.
15:45:27 T:18446744072511986768  NOTICE: Opening stream: 0 source: 256
15:45:27 T:18446744072511986768  NOTICE: Creating video codec with codec id: 2
15:45:27 T:18446744072511986768  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
15:45:27 T:18446744072503032328  NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 96001, pass-through)
15:45:27 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - dup error(300000.000000), clock(-300000.000000), correction(288000.000000)
15:45:27 T:18446744072508090608  NOTICE:  fps: 25.000000, pwidth: 720, pheight: 576, dwidth: 720, dheight: 405
15:45:27 T:18446744072508090608  NOTICE: Display resolution DESKTOP : 1920x1080 @ 60.000000 - Full Screen (16)
15:45:27 T:18446744072494383336  NOTICE: Using GL_TEXTURE_2D
15:45:27 T:18446744072494383336  NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
15:45:27 T:18446744072494383336  NOTICE: GL: NPOT texture support detected
15:45:27 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - dup error(44061.146108), clock(-11786.377000), correction(32000.000000)
15:45:28 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - dup error(313692.924048), clock(1152202.078000), correction(288000.000000)
15:45:37 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-36916872.103548), clock(36916872.103548), correction(32000.000000)
15:45:37 T:18446744072503032328 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
15:45:41 T:18446744072503032328 WARNING: Previous line repeats 12 times.
15:45:41 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-45398898.550041), clock(60976301.261548), correction(32000.000000)
15:45:41 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-94597.400027), clock(-39847.412000), correction(32000.000000)
15:45:41 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-62810.910919), clock(-71450.684000), correction(32000.000000)
15:45:41 T:18446744072503032328 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
15:45:41 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-43839.572602), clock(-87459.474000), correction(32000.000000)
15:45:41 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - dup error(36785.877048), clock(-43012.945000), correction(32000.000000)
15:45:42 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - dup error(111953.402719), clock(1034277.293329), correction(96000.000000)
15:45:44 T:18446744072503032328 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
15:45:53 T:18446744072503032328 WARNING: Previous line repeats 1 times.
15:45:53 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-7647745.817532), clock(7647745.817532), correction(32000.000000)
15:45:53 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - dup error(475670.720218), clock(7615745.817532), correction(448000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1449921.649473), clock(24963354.545224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1420027.362473), clock(24933918.021224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1388332.204143), clock(24908906.546224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1356331.872387), clock(24877211.723224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1324301.020631), clock(24845486.381224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1292300.690600), clock(24813761.039224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1260330.870119), clock(24782035.697224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1228330.532637), clock(24750310.355224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1196330.195156), clock(24718585.013224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1164299.339674), clock(24686829.154224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1132360.053094), clock(24655134.330224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1100298.694513), clock(24623378.470224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1068328.888933), clock(24591653.128224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1036328.567353), clock(24559927.787224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1004419.797772), clock(24528263.480224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-1021352.409772), clock(24567155.810224), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-94383.777027), clock(-40000.000000), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-62536.365027), clock(-71877.929000), correction(32000.000000)
15:46:02 T:18446744072503032328  NOTICE: CDVDPlayerAudio::OutputPacket forcing clock sync for passthrough - skip error(-33097.724083), clock(-101100.830000), correction(32000.000000)
15:46:02 T:18446744072503032328 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
15:46:06 T:18446744072494383336 WARNING: Previous line repeats 1 times.
15:46:06 T:18446744072494383336  NOTICE: CDVDPlayer::CloseFile()
15:46:06 T:18446744072494383336  NOTICE: DVDPlayer: waiting for threads to exit
15:46:06 T:18446744072511986768  NOTICE: CDVDPlayer::OnExit()
15:46:06 T:18446744072511986768  NOTICE: Closing stream player 1
15:46:06 T:18446744072511986768  NOTICE: Waiting for audio thread to exit
15:46:06 T:18446744072503032328  NOTICE: thread end: CDVDPlayerAudio::OnExit()
15:46:06 T:18446744072511986768  NOTICE: Closing audio device
15:46:06 T:18446744072511986768  NOTICE: Deleting audio codec
15:46:06 T:18446744072511986768  NOTICE: Closing stream player 2
15:46:06 T:18446744072511986768  NOTICE: waiting for video thread to exit
15:46:06 T:18446744072508090608  NOTICE: thread end: video_thread
15:46:06 T:18446744072511986768  NOTICE: deleting video codec
15:46:06 T:18446744072494383336  NOTICE: DVDPlayer: finished waiting
15:46:07 T:18446744072494383336  NOTICE: CDVDPlayer::CloseFile()
15:46:07 T:18446744072494383336  NOTICE: DVDPlayer: waiting for threads to exit
15:46:07 T:18446744072494383336  NOTICE: DVDPlayer: finished waiting
15:46:14 T:18446744072494383336  NOTICE: Storing total System Uptime
15:46:14 T:18446744072494383336  NOTICE: Saving settings
15:46:15 T:18446744072494383336  NOTICE: stop all
15:46:15 T:18446744072494383336  NOTICE: stop player
15:46:15 T:18446744072494383336  NOTICE: ES: Stopping event server
15:46:15 T:18446744072494383336  NOTICE: stopping upnp
15:46:15 T:18446744072494383336  NOTICE: stopping zeroconf publishing
15:46:15 T:18446744072494383336  NOTICE: WebServer: Stopped the webserver
15:46:15 T:18446744072502688008  NOTICE: ES: UDP Event server stopped
15:46:15 T:18446744072494383336  NOTICE: stop sap announcement listener
15:46:15 T:18446744072494383336  NOTICE: clean cached files!
15:46:15 T:18446744072494383336  NOTICE: unload skin
15:46:15 T:18446744072494383336  NOTICE: stopped
15:46:15 T:18446744072494383336  NOTICE: destroy
15:46:15 T:18446744072494383336  NOTICE: closing down remote control service
15:46:15 T:18446744072494383336  NOTICE: unload sections
15:46:15 T:18446744072494383336  NOTICE: special://profile/ is mapped to: special://masterprofile/
15:46:16 T:18446744072494383336  NOTICE: destroy
15:46:16 T:18446744072494383336 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
15:46:16 T:18446744072494383336 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
15:46:16 T:18446744072494383336 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
15:46:16 T:18446744072494383336 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
15:46:16 T:18446744072494383336 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
15:46:16 T:18446744072494383336 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
15:46:16 T:18446744072494383336 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
15:46:16 T:18446744072494383336 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
15:46:16 T:18446744072494383336 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
15:46:16 T:18446744072494383336 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
15:46:16 T:18446744072494383336 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
15:46:16 T:18446744072494383336  NOTICE: closing down remote control service
15:46:16 T:18446744072494383336  NOTICE: unload sections
15:46:16 T:18446744072494383336  NOTICE: application stopped...
