Full Version: Zidoo X9S (X-series) 4K HDR / 3D / HD Audio / ZDMC (Kodi fork): Review & Use
Hello,
I am having a problem with aeon mq8 2.9.0.
Once in ten when zdmc is started, the skin resets, causing me to lose all of my settings.
My config :
Zidoo Z9S (firm 2.3.10)
Zmdc 18.4
Aeon MQ8 2.9.0
Addon activated:
 AAC Encoder
AEON MQ8
AERIAL
Background overlays pack -basic
Backup
Black
Default controller
Dim
English
Estouchy
Estuary
Extendedinfo script
Extendedinfo script – open dialog
French
Joystick support
Kodi add-on repository
Kodi ui sounds
Kodi web interface -chorus2
Local information only
Movie genre icons – xzener’s flat icons
Recordlabel icons – white
Skin backgrounds – clear design
Skin backgrounds – darkwood design
Skin backgrounds – diamond design
Skin backgrounds – phenominence design
Skin helper service
Skin themes – aeon mq
Snes controller
Studio icons white
The movie database
Tv show – next aired
Universal album scraper
Universal artist scraper
Up next
Version check
Weather icons cloud animated
Weather icons default
Wma encoder
Youtube-dl control
Many Thanks
Hi all,
I've been using my x9s for 3D with a projector for years and loved it. Now finally have a 4k compatible projector but a bit confused by the 10 bit/12 bit settings. Aren't all 4k blu rays 10 bit natively (if we are excluding dolby vision which x9s can't do anyway)? Is there any benefit of using 12 bit setting therefore or should I force 10 bit? It seems to auto to 4:4:4 12 bit for playback...
This should help. You'll really want to invest in a Z9X however.
(2022-08-16, 01:06)hdmkv Wrote: [ -> ]This should help. You'll really want to invest in a Z9X however.
Thank you!!!!
