(2016-09-27, 02:41)wesk05 Wrote: [ -> ] (2016-09-26, 21:46)hdmkv Wrote: [ -> ]Would you please? What's special about that Rec.2020 sample CNXSoft tested with? I mean as opposed to the one whose MediaInfo I posted a couple of posts above?
Hmm.. the file that I have is only 506MB ( BT.2020.20140602.ts). It is the one in the second link and cnx-software's cloud.
I'll test it, no harm... can you please upload it somewhere? I seem to not be figuring out how to get into their cloud. Thanks.
(2016-09-27, 02:43)hdmkv Wrote: [ -> ]I'll test it, no harm... can you please upload it somewhere? I seem to not be figuring out how to get into their cloud. Thanks.
I'm uploading it now. Will post the link in about 20 min (TWC: only 5Mbps upload speed
Here is the link:
BT.2020.20140602.ts
(2016-09-27, 01:45)hdmkv Wrote: [ -> ] (2016-09-26, 20:17)boblo Wrote: [ -> ]Anyone could test DVD playback support (ISO / VIDEO_TS)? I think I'm not asking too much
DVD menu shows up, but you can't do anything w/it w/native player. Directional buttons, OK button, don't work; stays stuck on DVD menu. With ZDMC, DVD menu is usable.
Did you test chapter selection and subtitle compatibility? Does it play VIDEO_TS directories besides of ISO images?
Thank you
(2016-09-26, 20:28)OlivierQC Wrote: [ -> ]@ hdmkv,
i found this on CNX software :
Where to get video, audio and image samples
http://www.cnx-software.com/2010/03/17/w...e-samples/
December 7th, 2014 at 11:58 | #14 Reply | Quote
Rec.2020 (BT.2020) sample:
http://yunpan.cn/cg7DATekIkv3k password: c995
Mirror: http://pan.baidu.com/s/1dGoRs password: vkel
BT.2020.20140602.ts :
This video file is I share to him,the original information is as follows:
File: G:\003\4K.H.265\128Ku.4K.2014.40602首播.ts
Modified: 2014年6月3日, 12:33:50
MD5: E9F426B33F6B07C9ACAC75F551D1D325
SHA1: 2E3061FBD82E869B97CE9814EBB94FFD57BAC523
CRC32: 8AEAE4F8
General
Complete name : G:\003\4K.H.265\128Ku.4K.2014.40602首播.ts
Format : MPEG-TS
File size : 547 MiB
Duration : 2 min 4 s
Start time : UTC 2014-06-02 11:09:30
End time : UTC 2014-06-02 11:11:30
Overall bit rate mode : Variable
Overall bit rate : 36.9 Mb/s
Network name : |公样!
Original network name : Astra 8
Frequency : 12268000000
OrbitalPosition : 128.0E
Video
Menu ID : 33270 (0x81F6)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main [email protected]@Main
Codec ID : 36
Duration : 18 h 12 min
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 59.940 (60000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : BT.2020
Matrix coefficients : BT.2020 non-constant
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 2
Format profile : LC
Muxing mode : ADTS
Codec ID : 15
Bit rate mode : Variable
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 spf)
Compression mode : Lossy
Delay relative to video : -340 ms
Menu
List : 4109 (0x100D) (HEVC) / 4173 (0x104D) (AAC)
Service name : Channel!!4K
Service type : user defined
UTC 2014-06-02 11:00:00 : ja:F|K\蜪w7J$;~a / ja:F|K\蜪w7J$+;~a / IY;N;3<~JU蜪w7J1GA| / economics/social advisory / / 00:30:00
UTC 2014-06-02 11:30:00 : ja:F|K\蜪w7J$;~a / ja:F|K\蜪w7J$+;~a / IY;N;3<~JU蜪w7J1GA| / economics/social advisory / / 00:30:00
UTC 2014-06-02 16:10:00 : ja:?Channel 4K ?|坤抚谷 / ja:?Channel 4K ?|坤抚谷 / }麎Channel 4K婞?J|AwM=Dj蜨VAH?R2p忿国 / reserved for future use / / 00:20:00
UTC 2014-06-02 16:30:00 : ja:?Channel 4K ?|坤抚谷 / ja:?Channel 4K ?|坤抚谷 / }麎Channel 4K婞?J|AwM=Dj蜨VAH?R2p忿国 / reserved for future use / / 00:20:00
UTC 2014-06-02 16:50:00 : ja:?Channel 4K ?|坤抚谷 / ja:?Channel 4K ?|坤抚谷 / }麎Channel 4K婞?J|AwM=Dj蜨VAH?R2p忿国 / reserved for future use / / 00:20:00
UTC 2014-06-02 17:10:00 : ja:?Channel 4K ?|坤抚谷 / ja:?Channel 4K ?|坤抚谷 / }麎Channel 4K婞?J|AwM=Dj蜨VAH?R2p忿国 / reserved for future use / / 00:20:00
UTC 2014-06-02 17:30:00 : ja:?Channel 4K ?|坤抚谷 / ja:?Channel 4K ?|坤抚谷 / }麎Channel 4K婞?J|AwM=Dj蜨VAH?R2p忿国 / reserved for future use / / 00:20:00
UTC 2014-06-02 17:50:00 : ja:?Channel 4K ?|坤抚谷 / ja:?Channel 4K ?|坤抚谷 / }麎Channel 4K婞?J|AwM=Dj蜨VAH?R2p忿国 / reserved for future use / / 00:20:00
X9S TEST:
very smooth
mirror88, requesting source code again. What is going on please?
(2016-09-27, 01:45)hdmkv Wrote: [ -> ]DVD menu shows up, but you can't do anything w/it w/native player. Directional buttons, OK button, don't work;
Known issus,Already solved it,will upgrade it in next firmware.
hm. no mention on openWRT part ?
(2016-09-27, 08:21)HaoSs Wrote: [ -> ]hm. no mention on openWRT part ?
openWRT isn't related to media and especially to Kodi. It is additional function of the box. Here all about playing of media.
openWRT is a firmware/OS for routers. Not sure what that has to do with Zidoo at all...
(2016-09-27, 10:12)Koying Wrote: [ -> ]openWRT is a firmware/OS for routers. Not sure what that has to do with Zidoo at all...
The options openWRT are added to a functionality of Zidoo X9S:
SMB-server with web-console
torrent-client
and more...
(2016-09-27, 10:21)DenisDA Wrote: [ -> ]The options openWRT are added to a functionality of Zidoo X9S:
Yeah, it apparently can run openWRT, but is definitely for another purpose than a media player...
(2016-09-27, 10:42)Koying Wrote: [ -> ] (2016-09-27, 10:21)DenisDA Wrote: [ -> ]The options openWRT are added to a functionality of Zidoo X9S:
At Zidoo X9S modules from openWRT are fastened to the Android kernel though they advertize it as two systems.
