Full Version: Aeon Nox 5
Hi, newbie calling and I'm not a techie!
Why does the Xuum skin manage to override my Aeon Nox5 settings every now and again?
I have a GoStreamer Quadcore Android box running Jarvis 16.1.
Connected to my TV with Ethernet running on my fibre-optic 300mb SDSL account.
I like AeonNox5 as connected to a Trakt.tv account. This setup works fine for me.
But, as I said, every so often I power up my unit to find Xuum (using Confluence) has automatically replaced my skin.
Ok so I have to go through and change all the settings back and it's fine for a while then bang it does it again.
I can't see why/how this happens - any ideas pleeeeeeeease?
What version of Kodi are you using? It matters as Kodi changed how skin settings are retrieved. EDIT: Jarvis you said, sorry.. still recommend you follow below..
Also though I have no idea what that system you are using is.. I would suggest uninstalling ALL versions of Kodi, and ALL skins... then reinstalling the version of Kodi you want to use, then install Nox 5, that's just my opinion though as I have no idea about your system.
As nobody has answered you yet, that's all I can think of. Just backup the skin settings of the Xuum skin if you don't wanna lose them
Good luck friend!
