Full Version: HDHomeRun DVR Issue?
I am having an issue with the HDHomeRun DVR. I pledged $60 and got the early access DVR. I then installed it on my NAS and it all worked ok. Finally, I found an add-on for Kodi but I think it is the wrong one, not the SiliconDust one. It is the TVJunkieMod one.
The problem is, I don't know where the SiliconDust HDHomeRun add-on is. I have put in a problem ticket with them, but that was 2 days ago and haven't heard back from them yet. Can anyone here give me a hand and let me know what I am missing? The issue is that I was told that I should be getting 2 weeks of EPG (Electronic Program Guide) data and I am only getting 4 hours.
Thank You,
Mike LaPointe
Thank You jdlive. I am still having an issue.
First I went back to my email from them and reinstalled on my Windows 10 box and this time I used the activation code. I must have missed that last time.
Then I went back into Kodi and tried again. It has not changed. I can still see the HDHomeRun TV and Live TV works, but the DVR does not. I get the Search and Exit screen when I hit escape. I also only get about 3 hours of the program guide.
I tried reinstalling the DVR portion on my NAS (WD My Cloud 4 TB) and it says it worked successfully. I also did both options of stopping and starting the Record engine (the second post on https://www.silicondust.com/forum/viewto...19&t=41088) on my NAS. That all occurred successfully but still there is no DVR capability on Kodi. I am getting fairly frustrated. Sad
If anyone can give me a hand, I would really appreciate it.
Thank You,
Mike
This is for the PVR plugin, not SD's HDHomeRun View Kodi plugin.
@mlapoint1 - that add-on is specific to the Silicondust forums - you can find the original thread as well ass support here: https://www.silicondust.com/forum/viewto...88&t=19162
Ok, Thank You's go to both bry and jdlive. It is working now.
However, I just checked and I am getting 3 weeks of the program guide with the normal HDHomeRun client on my Windows 10 PC, but I still only get about 4 hours on my Kodi add-on. I thought I should be getting the same amount of guide in the add-on as I get from the HDHomeRun client?
Thank You,
Mike
