Full Version: ¿how to enable RGB scart output?
I have pal version of xbox and i want to ust scart rgb output. I bought av-pack but xbmc dont enable rgb output. This is xbmc.log:
3:31:34 M: 57864192 NOTICE: Getting hardware information now...
13:31:34 M: 57864192 NOTICE: Checking resolution 10
13:31:34 M: 57864192 NOTICE: Setting autoresolution mode 7
13:31:34 M: 57864192 NOTICE: Getting hardware information now...
13:31:34 M: 57843712 NOTICE: Checking resolution 10
13:31:34 M: 57843712 NOTICE: Setting autoresolution mode 7
13:31:34 M: 57843712 NOTICE: Per AV pack settings are off
Mode 7 is svideo not scart rgb output.
Any idea?
Thanks for all.
In av pack i have a switch button to toogle betwen av and rgb but it has no effect.
huh?
mode 7 is pal 16x9
nothing to do with the video encoder, that happens at a later stage (specifically in that nice black box sitting outside your xbox)
yes, but in old xbmc v2 tell me thats information:
19-10-2007 13:37:24 NOTICE Getting hardware information now...
19-10-2007 13:37:24 INFO Using analog output
19-10-2007 13:37:24 INFO AC3 pass through is disabled
19-10-2007 13:37:24 INFO DTS pass through is disabled
19-10-2007 13:37:24 NOTICE Checking resolution 7
19-10-2007 13:37:24 INFO AV Pack: S-Video
19-10-2007 13:37:24 INFO AV Flags: Widescreen
av pack s-video..
How can i change thist? av pack its only a little box with a small switch "rgb or av".
Are any probe to know if i see xbmc in rgb mode or svideo mode?
I have normal dvd-video witch have a button to change into rgb, cvgs or svideo and my crt tv works in alls modes..
no idea why your box doesnt ground the rgb pin, sorry. probably crappy hw (there's tons of crappy 3rd party av packs out there..)
