Yesterday I tried without success to animate an image when I moved up/down in a list (episode view)
The image is not in the layoutitem / focuslayoutitem
I used Conditionnal Type and tried with Container().OnNext and Container().OnPrevious
and other thing ...
I'm on Krypton (last alpha)
Is this possible ?
if yes, can someone give me a tip ?
cheer
Use a 'Visible' condition animation and add this visible condition -
<visible>!Container.OnNext + !Container.OnPrevious</visible>
hi Hitcher
Thx for the reply.
I have already done this
and I thought it didn't work.
The thing is, I had 2 animations on this image
one with Visible Type
the other with Hidden Type
indeed your example works when i use only one animation (type visible/visiblechange)
but now I guess this is impossible to have this 2 animation
maybe is there an other way
what I exactly want to perform is :
* on a video view (like movie / episode / season / tvshow)
* when the container list is OnNext / OnPrevious
* perform an effect on an image ( ListItem.Thumb) outside the list container
=> the old focus item thumb get out the windows with a slide effect (to left side) for example
=> the new focus item thumb get in the windows with a slide effect (from right side) for example
I see there is Container(id).ListItem(offset).Thumb (never try it before)
maybe I have to use 2 image (or 3 - 1 fore the current thumb, 1 for the previous, and 1 for the next) ?
Container(id).ListItem(-1).Thumb is previous thumb, 0 is focused item.
Thx badass,
but unfortunately, I can't achieve what I want to do.
I'm gonna keep it simple
You can create a fake hidden button and use onfocus and setproperty.
Featherence |
YouTube
hi finalmakerr,
not sure where you want to go with this
but nevermind, I gave up
i dont have enought time
and i want to finish a functionnal mod before Krypton release
so I will keep it simple
thx anyway !
