I'm using Kodi 16 in a VuPlus Solo2 enigma2 box (sat+dtt tv decoder)... it runs so well, but when changing Kodi Skin it gives me always an error...
Anyone here knows if it's possible to change the skin of a Kodi running in an enigma2 box?
Thnx!
Can you give more details on the exact error, and if possible gather a
debug log (wiki) of a failed attempt at a switch, upload it to pastebin.com or somewhere similar and supply the link they will give you here?
Sorry, my mistake,... now I'm able (not hd space) Thanks!
Again me.... I'm able to install different skins to Kodi on vuplus solo2 with BH 3.0.2.G... but I'm getting errors in the main Movies 'screen' like "error loading bookmarks" "error loading new movies links" etc...
Same on TV Shows main screen...
The latest added movies or tv shows Cover are not shown...
Cheers!
same answer, we really need a
Debug Log to be able to help ;-)
(2016-09-27, 10:11)ronie Wrote: [ -> ]same answer, we really need a Debug Log to be able to help ;-)
When I activate Aeon Nox skin for example I get two erroes:
Error toolbox script
Error Skin Shortcuts (this is the one I get with every skin but Confluence)
The log file comes here:
20:16:45 T:1984860160 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:16:45 T:1984860160 NOTICE: -----------------------------------------------------------------------
20:16:45 T:1984860160 NOTICE: Starting Kodi (16.1-RC2 Git:2016-04-06-528f9f8-dirty). Platform: Linux MIPS 32-bit
20:16:45 T:1984860160 NOTICE: Using Release Kodi x32 build
20:16:45 T:1984860160 NOTICE: Kodi compiled Apr 6 2016 by GCC 4.9.2 for Linux MIPS 32-bit version 3.19.0 (201472)
20:16:45 T:1984860160 NOTICE: Running on Unknown Linux Distribution 0.0, kernel: Linux MIPS 32-bit version 3.13.5
20:16:45 T:1984860160 NOTICE: FFmpeg version: 2.8.6-kodi-2.8.6-Jarvis-16.0
20:16:45 T:1984860160 NOTICE: Host CPU: BCM7346B2 STB platform, 2 cores available
20:16:45 T:1984860160 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
20:16:45 T:1984860160 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
20:16:45 T:1984860160 NOTICE: special://masterprofile/ is mapped to: /media/hdd/.kodi/userdata
20:16:45 T:1984860160 NOTICE: special://home/ is mapped to: /media/hdd/.kodi
20:16:45 T:1984860160 NOTICE: special://temp/ is mapped to: /tmp/kodi
20:16:45 T:1984860160 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
20:16:45 T:1984860160 NOTICE: Local hostname: vusolo2
20:16:45 T:1984860160 NOTICE: Log File is located: /tmp/kodi/kodi.log
20:16:45 T:1984860160 WARNING: Unicode properties are not enabled in PCRE lib, support for national symbols may be limited!
20:16:45 T:1984860160 NOTICE: Consider installing PCRE lib version 8.10 or later with enabled Unicode properties and UTF-8 support. Your PCRE lib version: 8.36 2014-09-26
20:16:45 T:1984860160 NOTICE: load settings...
20:16:45 T:1984860160 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
20:16:45 T:1984860160 NOTICE: Change AESink retry count..
20:16:45 T:1984860160 NOTICE: AESink retry count - 1
20:16:45 T:1984860160 NOTICE: No Devices found - retry: 1
20:16:46 T:1984860160 NOTICE: Found 0 Lists of Devices
20:16:46 T:1984860160 NOTICE: Change AESink retry count..
20:16:46 T:1984860160 NOTICE: AESink retry count - 1
20:16:46 T:1984860160 NOTICE: No Devices found - retry: 1
20:16:48 T:1984860160 NOTICE: Found 0 Lists of Devices
20:16:48 T:1984860160 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
20:16:48 T:1984860160 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
20:16:48 T:1984860160 NOTICE: Default DVD Player: dvdplayer
20:16:48 T:1984860160 NOTICE: Default Video Player: dvdplayer
20:16:48 T:1984860160 NOTICE: Default Audio Player: paplayer
20:16:48 T:1984860160 NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:16:48 T:1984860160 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
20:16:48 T:1984860160 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
20:16:48 T:1984860160 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:16:48 T:1984860160 NOTICE: Loaded playercorefactory configuration
20:16:48 T:1984860160 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:16:48 T:1984860160 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:16:48 T:1984726096 NOTICE: Change AESink retry count..
18:16:48 T:1984726096 NOTICE: AESink retry count - 1
18:16:48 T:1984726096 NOTICE: No Devices found - retry: 1
18:16:49 T:1984726096 NOTICE: Found 0 Lists of Devices
18:16:49 T:1984860160 NOTICE: Running database version Addons20
18:16:50 T:1984860160 NOTICE: ADDONS: Using repository repository.xbmc.org
18:16:50 T:1984860160 NOTICE: InitWindowSystem: Using EGL Implementation: vuplus
18:16:50 T:1984860160 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
18:16:50 T:1984860160 NOTICE: Previous line repeats 2 times.
18:16:50 T:1984860160 NOTICE: Found ([email protected]) at 16, setting to RES_DESKTOP at 16
18:16:50 T:1984860160 NOTICE: Checking resolution 16
18:16:50 T:1984860160 NOTICE: GL_VENDOR = Broadcom
18:16:50 T:1984860160 NOTICE: GL_RENDERER = VideoCore IV HW (V3D-410)
18:16:50 T:1984860160 NOTICE: GL_VERSION = OpenGL ES 2.0
18:16:50 T:1984860160 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
18:16:50 T:1984860160 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_APPLE_rgb_422 GL_OES_packed_depth_stencil GL_EXT_debug_marker GL_EXT_multisampled_render_to_texture GL_EXT_texture_format_BGRA8888
18:16:51 T:1984860160 NOTICE: Running database version Addons20
18:16:51 T:1984860160 NOTICE: Running database version ViewModes6
18:16:51 T:1984860160 NOTICE: Running database version Textures13
18:16:51 T:1984860160 NOTICE: Running database version MyMusic56
18:16:51 T:1984860160 NOTICE: Running database version MyVideos99
18:16:51 T:1984860160 NOTICE: Running database version TV29
18:16:51 T:1984860160 NOTICE: Running database version Epg11
18:16:53 T:1984860160 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
18:16:53 T:1984860160 WARNING: Skin has invalid include: skinshortcuts-submenu
18:16:54 T:1984860160 NOTICE: ActiveAE DSP - starting
18:16:54 T:1984860160 NOTICE: initialize done
18:16:54 T:1984860160 NOTICE: Running the application...
18:16:54 T:1984860160 NOTICE: starting zeroconf publishing
18:16:54 T:1984860160 NOTICE: WebServer: Started the webserver
18:16:54 T:1984860160 NOTICE: starting upnp client
18:16:54 T:1516237904 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:16:54 T:1516237904 NOTICE: UDP: Listening on port 9777
18:16:54 T:1984860160 WARNING: no keymap support (requires /dev/tty0 - CONFIG_VT)
18:16:57 T:1654649936 WARNING: Previous line repeats 1 times.
18:16:57 T:1654649936 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named PIL
File "/media/hdd/.kodi/addons/script.toolbox/default.py", line 6, in <module>
from resources.lib.Utils import *
File "/media/hdd/.kodi/addons/script.toolbox/resources/lib/Utils.py", line 9, in <module>
from PIL import Image, ImageOps
ImportError: No module named PIL
18:16:58 T:1673462864 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.15)
18:17:01 T:1698628688 NOTICE: script.grab.fanart: Grab Fanart Service Started
18:17:05 T:1627341904 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Contents: No module named cProfile
File "/media/hdd/.kodi/addons/script.skinshortcuts/default.py", line 6, in <module>
import cProfile
ImportError: No module named cProfile
18:17:05 T:1681851472 NOTICE: Skin Helper Service --> skin helper service version 1.0.100 started
18:17:05 T:1681851472 NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
18:17:11 T:1474294864 NOTICE: script.module.youtube.dl: youtube_dl core version: 2016.06.27
18:17:11 T:1474294864 NOTICE: version 4.6.1 started
18:17:21 T:1654649936 NOTICE: script.module.youtube.dl: youtube_dl core version: 2016.06.27
18:17:21 T:1654649936 NOTICE: version 4.6.1 started
18:17:30 T:1654649936 WARNING: Attempt to use invalid handle 4
18:17:30 T:1654649936 WARNING: Previous line repeats 29 times.
18:17:30 T:1654649936 NOTICE: finished
18:17:34 T:1474294864 WARNING: Attempt to use invalid handle 3
18:17:34 T:1474294864 WARNING: Previous line repeats 29 times.
18:17:34 T:1474294864 NOTICE: finished
18:17:35 T:1644119120 ERROR: GetDirectory - Error getting include
18:17:35 T:1440740432 NOTICE: script.module.youtube.dl: youtube_dl core version: 2016.06.27
18:17:36 T:1440740432 NOTICE: version 4.6.1 started
18:17:41 T:1440740432 WARNING: Attempt to use invalid handle 5
18:17:41 T:1440740432 WARNING: Previous line repeats 29 times.
18:17:41 T:1440740432 NOTICE: finished
18:17:47 T:1465906256 NOTICE: script.module.youtube.dl: youtube_dl core version: 2016.06.27
18:17:47 T:1465906256 NOTICE: version 4.6.1 started
18:17:51 T:1465906256 WARNING: Attempt to use invalid handle 6
18:17:51 T:1465906256 WARNING: Previous line repeats 29 times.
18:17:51 T:1465906256 NOTICE: finished
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=207932
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=258230
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=302946
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=343611
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=286567
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=339408
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=412467
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=374251
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=377447
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=375183
18:17:52 T:1644119120 ERROR: InputStream: Error opening, plugin://script.extendedinfo/?info=extendedinfo&&id=375183
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=369883
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=337844
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=345009
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=369237
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=340676
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=412924
18:18:55 T:1465906256 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/
18:18:58 T:1963979856 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting GUI proc (6.0.15)
18:19:03 T:1644119120 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/
18:19:21 T:1440740432 ERROR: Previous line repeats 1 times.
18:19:21 T:1440740432 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
import cProfile
18:19:24 T:1644119120 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/DR1.png
18:19:26 T:1654649936 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting GUI proc (6.0.15)
18:20:01 T:1474294864 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/National Geographic (US).png
18:20:03 T:1465906256 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/FX (US).png
18:20:06 T:1474294864 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/Sky Atlantic (UK).png
18:20:11 T:1474294864 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/
18:20:18 T:1440740432 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
import cProfile
18:20:19 T:1644119120 ERROR: GetDirectory - Error getting 13
18:20:25 T:1654649936 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting GUI proc (6.0.15)
18:20:33 T:1440740432 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
import cProfile
moving to linux...
perhaps you should try to ask this question on the vu+ support forum...
looks like your system is missing some python libraries, causing addons to fail.
what ronie said. Whoever ported kodi to this platform missed some stuff.
Thanks my friends! I've asked there, but ... :-)
BTW do you know which python libraries are missed¿? profile.py?
Thnx!
at least these libraries are missing:
I've just pushed an update to
Skin Shortcuts git so that cProfile is no longer required (unless the script is actually being profiled) which will at least allow that script to run on your system. However I come across such systems without all of the Python default libraries with reasonable regularity and agree with Ronie that the ultimate solution is absolutely to go back to your provider and encourage them to provide a complete Python implementation.
(2016-09-29, 00:04)BobCratchett Wrote: [ -> ]I've just pushed an update to Skin Shortcuts git so that cProfile is no longer required (unless the script is actually being profiled) which will at least allow that script to run on your system. However I come across such systems without all of the Python default libraries with reasonable regularity and agree with Ronie that the ultimate solution is absolutely to go back to your provider and encourage them to provide a complete Python implementation.
Thanks BobCratchett... I've deployed your skin.shortcuts update into my Kodi (./kodi/addons/script.skinshortcuts) and now I don't get script.skin shortcut error, but still getting Error toolbox script ... I think it's related to PIL python lib...
BTW: i've already asked vuplus people to add all python libs... in vu-plus community forum, but no anwser..
I may be mis-remembering here, but if I do remember correctly then on Linux the Python used is the system version - rather than the version built along with Kodi - so, and if I'm remembering correctly, it's worth checking if you can manually update the Python version on your system.
