OK so we are looking at a feature to show Logo artwork for Add-ons in Kodi and on the front-end repository.
This feature will only be implemented if people show some interest making them...
Please post any you create here:
Example
Aeon Nox 5
Feel free to request any you want.
Nice logo tutorial here for GIMP which is opensource and free.
I have been wanting to change/update my current logo to more match the uppercase besides the "i" look that I have chosen to use in the skin and my username.
Current logo:
Would really appreciate a new one for the skin.
Are there any rules as far as size and aspect ratio? Are transparent backgrounds ok?
Do not start to make up new rules. Maintain the rules from fanart.tv as you can then reuse the current views without needing to adjust.
Yep as Martijn says:
Rules
- 800 wide x 310 long
- Transparent PNG
- 10 pixel gutter on each side on the widest or longest part
- Always test on both dark and white backgrounds (Apply a drop shadow or glow to make it work on both)
You can use this template to test it in GIMP or Photoshop
This will future proof them for a 4K world
Amber Skin
Xperience1080
EDIT: Removed at skin authors request
(2016-09-28, 20:43)mikeSiLVO Wrote: [ -> ]I have been wanting to change/update my current logo to more match the uppercase besides the "i" look that I have chosen to use in the skin and my username.
Current logo:
Any ideas what font you want the "silvo" name to be in?
Anything from here can be fine
http://www.dafont.com/
Ah, I was confused when you said "banner artwork", as that is quite different. I'll create a clear logo for Mimic and post it here.
(2016-10-03, 16:09)braz Wrote: [ -> ]Ah, I was confused when you said "banner artwork", as that is quite different. I'll create a clear logo for Mimic and post it here.
Ahh thanks, copy/paste error. Fixed now.
There is a banner thread too in this forum
I've asked if tamland could add core support and server backend.
May tweak it some, but here's one for now...
(2016-10-03, 14:08)zag Wrote: [ -> ]Any ideas what font you want the "silvo" name to be in?
Anything from here can be fine http://www.dafont.com/
Oh, jiminy... That is a tough one. I will comb through that site today.
I don't have much faith in my artistic ability so if you have any ideas for something that will look good I am sure it would be better than anything I might pick
App TV
