2016-09-28, 13:10
2016-09-28, 13:10
2016-09-28, 13:26
maybe same issue as mentioned here: http://forum.kodi.tv/showthread.php?tid=...light=hevc
Only Windows seems to be affected by those kind of issues.
2016-09-28, 14:03
Curious ShadeBlack, Guest_101 and me have the same CPU: i3-6100 Skylake .
I will test disable some enhancement under Video Settings in Intel HD Graphic Control Panel.
But native in DVBViewer or MPC-HC works fine with the same Intel HD Graphic Control Panel setup. Seems a bug in Kodi v17.
2016-09-28, 20:45
Disable contrast enhancement in the video settings works fine now
2017-01-07, 12:23
(2016-09-28, 20:45)fischgourmet Wrote: [ -> ]Disable contrast enhancement in the video settings works fine now
Thank you! This worked for me as well (I'm using an Intel Kaby Lake with a HD graphics 620)
2017-02-06, 03:59
(2017-01-07, 12:23)stinuz Wrote: [ -> ](2016-09-28, 20:45)fischgourmet Wrote: [ -> ]Disable contrast enhancement in the video settings works fine now
This worked for me as well on the newest Intel NUC (the Skull Canyon NUC6i7KYK).
