2016-09-28, 16:43
please help! new user.
I installed Kodi the latest current version Kodi v16.1 “Jarvis” (mac) from the official site https://kodi.tv/download/
I had a problem closing Kodi (would not close) so i forced close in my MacBook pro (sierra), problem closing every single time
so I decided to do a remove and reinstall of Kodi by:
1-dragging and dropping the kodi app into the trash bin
2-dragged and dropped the kodi 16.1 jarvis dmg file into the trash bin
3-went to finder in Library\application support\ and delete the Kodi folder
4-emptied the trash bin
5-restarted macbook pro (sierra)
6-redownloaded the kodi dmg file
7-double click the file, dragged it into the application folder just as the first install
when i start Kodi it says “Kodi” is damaged and can’t be opened. You should move it to the Trash.
yes i searched and read the forums and spend all day trying all of the great advice given in other forums, please be patient because i didn't want to frustrate anyone in here with the same question, but i have tried everything.
i clean the MacBook pro from any files and folders but when i reinstall i still get the same message, and i have noticed that the kodi folder doesn't get created in the application support folder
what to do?
what to do?
