Sinnocence Wrote:Had absolutely no luck getting this fixed so I removed compiz (*everything*) and tried again.
Worked first time.
too fast - forgot the quote!
@sinnocence: tonight i'll try to install mythbuntu 7.10 and xbmc - should work, because it doesnt has compiz included.
seven5 Wrote:Nope, it segfaults
Then thats probable not the reason because if it segfaults its not going to write in the log what the problem is
but when I next boot my linux box I will delete mine and see if it makes a difference
Ok, i totally reinstalled Ubuntu 7.10
Installed video drivers with the normal restricted drivers method, did NOT use Envy
I determined that xbmc was opening without segfault.
I then edited my xorg.conf file to get my appropriate resolution. I'm now at 1360x768, and i get a segfault. Here is my xorg.conf, is there something in there that shouldn't be?
# xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "us"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/input/wacom"
Option "Type" "stylus"
Option "ForceDevice" "ISDV4"# Tablet PC ONLY
Sory, apparently i can't edit the post and i didn't paste the whole conf in, here it is:
# package.
Section "Files"
EndSection
Driver "kbd"
EndSection
Driver "mouse"
EndSection
Driver "wacom"
Identifier "stylus"
EndSection
Driver "wacom"
Identifier "eraser"
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
Option "Type" "cursor"
EndSection
Section "Device"
Identifier "Generic Video Card"
Driver "nvidia"
Busid "PCI:0:5:0"
Option "AddARGBVisuals" "True"
Option "AddARGBGLXVisuals" "True"
Option "NoLogo" "False"
Option "ModeValidation" "NoEdidModes"
EndSection
Section "Monitor"
Identifier "Failsafe Monitor"
Vendorname "Generic LCD Display"
Modelname "LCD Panel 1360x768"
Horizsync 31.5-48.0
Vertrefresh 56.0 - 65.0
#modeline "640x480@60" 25.2 640 656 752 800 480 490 492 525 -vsync -hsync
#modeline "800x600@56" 36.0 800 824 896 1024 600 601 603 625 +hsync +vsync
#modeline "800x600@60" 40.0 800 840 968 1056 600 601 605 628 +hsync +vsync
#modeline "1024x768@60" 65.0 1024 1048 1184 1344 768 771 777 806 -vsync -hsync
modeline "1360x768@60" 84.72 1360 1424 1568 1776 768 769 772 795 -hsync +vsync
Gamma 1.0
EndSection
EndSection
Section "Monitor"
Horizsync 31.5-48.0
Gamma 1.0
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Generic Video Card"
Monitor "Failsafe Monitor"
Defaultdepth 16
SubSection "Display"
Depth 16
Modes "1360x768@60"
#Modes "1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
screen "Default Screen"
Inputdevice "Generic Keyboard"
Inputdevice "Configured Mouse"
# Uncomment if you have a wacom tablet
# InputDevice "stylus" "SendCoreEvents"
# InputDevice "cursor" "SendCoreEvents"
# InputDevice "eraser" "SendCoreEvents"
EndSection
Section "Module"
Load "glx"
EndSection
Ok I'm no linux guru far far far from it infact but these bits look wrong to me having 2 Monitor things exactly the same and one extra EndSection
Horizsync 31.5-48.0
Gamma 1.0
EndSection
EndSection
Section "Monitor"
Horizsync 31.5-48.0
Gamma 1.0
EndSection
arg, thats just a paste error, i assure you those aren't in there.
SHould i fork out of this thread since it has nothing to do with the missing files?
