Full Version: How to remove a small info panel while video pause
New to Titan & Jarvis.
Kindly help me remove this panel (as pointed in the attached img) that pops up when I pause a video.
or
http://i64.tinypic.com/2e3aoo6.jpg
What do you want instead ? Just a frozen video with no indication that it is paused at all ?
Yes, If it is possible then I would l need it greatly.
Probably the modest feature request Marcel ever got ;-)
Hi Marcel,
Should I be lookin out for it or Stop?
Thamks
Vikram.
Will be fixed in next skin update...
Thank You Marcel.
Regards,
Capt Vikram Sandhu
Now I see who asked to remove it Smile
Because I think it was good that it's there.
Marcel, as I told you on the other thread, please add an option also for the small OSD Enable/Disable.
Yes, I will make it an option
