With v1.2.1 everything works now.
Thank you very much @
phate89.
Hi Phate89,
Can you be so kind to update this version 1.2.1 also for Kodi 14.2 on ubuntu linux please.
I'm trying to upgrade from 14.2 to 16.1 but there are a lot of addons and skin that crash everything and I would like to don't loose all my setup, please.
Kodi version xbmc.python xbmc.gui xbmc.json xbmc.metadata xbmc.addon
Helix 14.x 2.19.0 (ABI 2.1.0) 5.3.0 6.20.0 (ABI 6.0.0) 2.1.0 14.0.0 (ABI 12.0.0)
I also tried to upgrade your script but kodi continue to say that Structure is not correct!
If you want I can make a donation to you.
Let me know.
Fabio
Version 1.2.1 stopped working.
When you try to open a video you receive "error".
Could you please fix?
Thank you!!
No it works ...i tried it out ten minutes ago .
Good evening, I have a problem with the installation script on the SPMC, Ghotam version (very stable version for the TV box in question). The addon (1.2.1) installed (addon.xml editing the file), but the script does not come out the bottom of the message has been enabled and therefore the video does not start.
How can I fix? Thanks so much!
is not working again...pl,ease fix it
tanks
same here ... not working they changed something again.
looking at log seems like GetDirectory() is failing.
UPDATE : div.main-container is not longer there so get_url_groupList() is failing to find it ... they changed to div.brandpage , I hope this will help , let me know if you need to do any test
UPDATE 2 : actually they change more than that, they reworked the structure of 'section'
same problem i'm using kodi 16.1
Yup, it stopped working only for the elanco programmi section. You can go to "Ultime" and bypass it to find your favorite episode or whatever. I tried playing with mediaset.py but I am no genius, so I gave up.
Thanks wizy. Almost perfect
Works perfectly. Thanks everyone for your hard work, you all rock!
