Full Version: Mediaset Play
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
It doesn't work on android
Any one have a fix for the Live channels?  The stream address changed again.
It seems that everything has changed....all Videos are gone ...All categories are empty .
Sorry false Alarm, it works....
This is still not working has their been a update to the app?  I have version 1.2.2 but is not working
Anyone got a new url?
(2018-04-04, 23:35)pjelar Wrote: [ -> ]Anyone got a new url?
 for what?
I think that something is not working today.. videos are not starting and if they start the video will stop awkwardly after a few seconds. Any workarounds?
The other video services like "Rai on Demand" are working as normal
(2018-04-10, 07:17)lucapoison Wrote: [ -> ]I think that something is not working today.. videos are not starting and if they start the video will stop awkwardly after a few seconds. Any workarounds?
Nevermind... seems like it works again.
So I'm seeing this weird issue, trying to play Quarto Grado aired Friday April 13th from Kodi I got an error "Not available in your country", playing it using chrome it works fine. Same PC, same network configuration, Chrome works, Kodi Video Mediaset addon throws the error. Only for Friday April 13th episode. All the other works fine also on Kodi.
Anyone else seeing this issue?
Yes the Same Problem here.
All the new episodes starting from 13.04 i cant watch 'this Video ist Not available for your country' ...addon
but on their website or app it works,
what could be the problem?
can someone help, would be great.
Hi All,
I have the same problem here in USA. Some programs can be seen, some other can't, returning the " this video is not available for your country " error.
Any help will be much appreciates, my wife is getting crazy...
I'm in Germany and I'm getting the same error.
Update: I just tried to open the same video that doesn't work in Kodi (last episode of Emigratis) on the actual website from my computer and works as normal with my German ip. That means that there's some problem with the Kodi Add-on. I kindly ask you to solve this problem as soon as possible... Thank you so much for your efforts!
Everyone has the same error as the problem is not related to geo-blocking, the message is just a generic video for content not found.
The issue is due to the fact that to obtain the actual URL to the mp4 video file the addon makes this query:
http://cdnsel01.mediaset.net/GetCdn2018....ormat=json
where 751387 is the id of the episode you want to play (that's a quarto grado episode from Sept 2017.
The response provides the URL to the video
{"state":"OK","code":"200","videoList":["http://vod06.msf.ticdn.it/farmunica/2017/09/92726_15e63b1c43da2f/15e63b1c43da2f-20_0.mp4"]}
Since Friday April 13th they changed something and this is not working anymore for any program and any new episode, for example 831002 is quarto grado episode from Friday 13th
This is the response:
{"state":"OK","code":"200","videoList":["http://vod06.msf.ticdn.it/error/Not_Available.mp4"]}
A different id must be used and it can be found in the shtml file specific to each episode on this line:
<article data-node="video" data-type="video" data-cid="831002" data-rid="831002" data-format="" data-codf="F308790901001201">
the data-codf field is the id to be used in the query above and in fact:
returns:
{"state":"OK","code":"200","videoList":["http://vod06.msf.ticdn.it/farmunica/2018/04/191535_162c130caef965/162c130caef965-20_0.mp4"]}
I applied a workaround that requires changing 4 lines on the mediaset.py file, it's super inefficient as I'm not a developer, so maybe someone can fix this in a more elegant manner.
Thanks marcoc
it would be great if someone could work on the Bug fix
