Full Version: smart playlists not giving expected results
I'm not new to smart playlists as I've used them for years on my Windows PC. However, I'm attempting to use very similar lists, but getting different results on Rpi running OSMC Kodi 16.1. I've tried Aeon Nox 5 Redux, Confluence and default skins with same results. I've made the required entries in the favourites.xml and keyboard.xml.
Working example playlist on PC:
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<smartplaylist type="movies">
    <name>All Movies</name>
    <match>one</match>
    <rule field="path" operator="contains">
        <value>smb://SERVER3/video/Movies/</value>
    </rule>
        <value>smb://SERVER3/video/Movie Sets/</value>
    </rule>
        <value>smb://SERVER3/video/Mom Shared/</value>
    </rule>
        <value>smb://SERVER3/video/Westerns/</value>
    </rule>
        <value>smb://SERVER3/video/Christmas/</value>
    </rule>
        <value>smb://SERVER3/video/Comedy/</value>
    </rule>
    <order direction="ascending">sorttitle</order>
</smartplaylist>
Rpi incorrect playlist: If I use contains I get ONLY all movie COLLECTIONS, even those not in the desired path, and therefore no movies from the Movies folder.
    <name>test</name>
    <match>one</match>
        <value>smb://KublerNAS1/Video/Movies/</value>
    </rule>
        <value>smb://KublerNAS1/Video/Movie Sets/</value>
    </rule>
</smartplaylist>
Rpi incorrect playlist: If I use startswith I get ALL movies and collections, even those not in the desired paths. So my entire library.
    <name>Movies and Sets</name>
    <match>one</match>
    <rule field="path" operator="startswith">
        <value>smb://KublerNAS1/Video/Movie Sets</value>
    </rule>
        <value>smb://KublerNAS1/Video/Movies</value>
    </rule>
</smartplaylist>
If I use "is", I get two dots "..".
BUMP
Doesn't anyone have an idea why these smart playlists aren't working?
