here is mine:
16:22:02 T:3432 NOTICE: Thread LanguageInvoker start, auto delete: false
16:22:02 T:3432 NOTICE: -->Python Interpreter Initialized<--
16:22:02 T:3432 NOTICE: [fslib]: Request URL:
https://media-api.foxsportsgo.com/sessio...e3/refresh
16:22:02 T:3432 ERROR: C:\Users\Phil\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\packages\urllib3\util\ssl_.py:315: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may cause the server to present an incorrect TLS certificate, which can cause validation failures. For more information, see
https://urllib3.readthedocs.org/en/lates...ingwarning.
SNIMissingWarning
16:22:02 T:3432 ERROR: C:\Users\Phil\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\packages\urllib3\util\ssl_.py:120: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see
https://urllib3.readthedocs.org/en/lates...ormwarning.
16:22:02 T:3432 NOTICE: [fslib]: Response code: 200
16:22:02 T:3432 NOTICE: [fslib]: Response: {"id":"53177bd8c02-11e6-878e-1237155ee1e3","type":"REGISTERED","ip_address":"50.88.14.20","device":{"id":"iapReceiptDevice
evice:5986c661a9-4eee-92e2-8707d87dc727:985380-27c6-4087-aa96-f3b83b9171c9","platform":"ios-tablet"},"user":{"id":"36745077-3362-441d-a489-6726b9e3f5e1-249320-e311ec89872fe86c5d0dcd1711e12647afcf7d","ipid":"iapReceiptDevice
evice:5986c69b-61a9-4eee-92e2-8707d8c727:985382f0-27c6-4087-aa96-f3b83b9171c9","billing_location":{"type":"ZIP_CODE","zip_code":"33325"},"registration":{"auth_provider":"DTV","entitlements":["fs2","fbc-fox","fs1","sunsports","fsfl"],"expires_on":"2016-11-05T20:20:18.000+0000"}},"generated_on":"2016-10-06T20:20:29.325+0000","updated_on":"2016-10-06T20:22:03.920+0000","expires_on":"2016-10-07T00:22:03.920+0000","available_content":{"national":{"call_signs":["BIGE","FS1","FS2","FSGO","FXDEP","USOPEN","FSP"]},"geo":{"location":{"type":"ZIP_CODE","zip_code":"32725","country_code":"us"},"rsn_channel_groups":["fsfl","sunsports"],"rsn_call_signs":["FSNFL1","SUNB"],"affiliate_call_signs":["WOFL"]},"home":{"location":{"type":"ZIP_CODE","zip_code":"33325"},"rsn_channel_groups":["fsfl","sunsports"],"rsn_call_signs":["FSNFL2","SUN"],"affiliate_call_signs":["WSVN"],"teams":[{"id":"7078084a-51d5-4f93-8b4e-4cf5e3c7f062","name":"Florida Panthers","sport":"NHL"},{"id":"25e592a7-5ac3-4637-ac4a-5aa890e47a2e","name":"Miami Heat","sport":"NBA"},{"id":"cc1176ca-660e-4217-868c-0fc6f44bfaee","name":"Miami Marlins","sport":"MLB"},{"id":"eab72336-56ad-4832-971d-e6a50114f815","name":"Tampa Bay Rays","sport":"MLB"}]}},"links":[{"rel":"self","method":"GET","href":"/sessions/53177bd0-8c02-11e6-878e-1237155ee1e3"},{"rel":"refresh","method":"PUT","href":"/sessions/53177bd0-8c02-11e6-878e-1237155ee1e3/refresh"}]}
16:22:02 T:3432 NOTICE: [fslib]: Session is still valid.
16:22:02 T:3432 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'xbmcgui.ListItem' object has no attribute 'setContentLookup'
File "C:\Users\Phil\AppData\Roaming\Kodi\addons\kodi-fsgo-master\default.py", line 224, in <module>
router(sys.argv[2][1:]) # trim the leading '?' from the plugin call paramstring
File "C:\Users\Phil\AppData\Roaming\Kodi\addons\kodi-fsgo-master\default.py", line 220, in router
init()
File "C:\Users\Phil\AppData\Roaming\Kodi\addons\kodi-fsgo-master\default.py", line 197, in init
main_menu()
File "C:\Users\Phil\AppData\Roaming\Kodi\addons\kodi-fsgo-master\default.py", line 71, in main_menu
add_item(item, parameters)
File "C:\Users\Phil\AppData\Roaming\Kodi\addons\kodi-fsgo-master\default.py", line 184, in add_item
listitem.setContentLookup(False) # allows sending custom headers/cookies to ffmpeg
AttributeError: 'xbmcgui.ListItem' object has no attribute 'setContentLookup'
16:22:03 T:15364 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.fsgo/
16:22:03 T:15364 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.fsgo/) failed
