2016-10-08, 20:55
Can someone help me increase the current limit of 10 for Recently added and unwatched. What code do i need to change in the xml files? I am using the default estuary.
<videolibrary>
<recentlyaddeditems>50</recentlyaddeditems> <!-- number of recently added items. Defaults to 25 -->
</videolibrary>
(2016-10-12, 03:54)terpsarlington Wrote: [ -> ]Thanks that worked.
(2016-11-12, 16:38)wkjoe Wrote: [ -> ]What I would really like to see would be several sort order options added to the regular views that Estuary provides. "In progress" sort order, "recently added episode" sort order, "unwatched" sort order, and "random" sort order. Then any view could provide the same functionality as the home screen, but with no limit to the number of items.
Anyway, I assume the way to increase the limit for android is the same as for any other version of kodi -- to edit the Includes_Home.xml file. Or are you saying that android does not have this file?
I just don't know exactly what to edit in that file. I did a search in that file for "10" (with the quotes) and >10< and I found a number of occurrences but I am not sure which to change.
