Hi Guys,
Has any tried yet to map a drive as local source originating from OneDrive?
I am trying something like the following; https://[user]:[psw]@d.docs.live.net/[CID]
It is possible to do so from Windows... am I crazy thinking that this should work from Kodi as well?
See:
https://www.maketecheasier.com/mapping-o...e-windows/
Regards
PS, Kodibuntu 16.04 / Jarvis 16.1
Well, the add-on is working pretty great but you cannot add a OneDrive source directly to the music library with it.
.. or I haven't found a way to do so
(2016-10-09, 11:04)hamec Wrote: [ -> ]Hi Guys,
See: https://www.maketecheasier.com/mapping-o...e-windows/
Regards
I would assume that once you map it as described in the link and it is recognised in Windows then a Kodi installation on Windows would see it? Not a Windows user so I can't test it.
Are you looking for a Linux / LibreElec solution as you've posted this in the Linux forum?
Can't comment there as I don't use it (either the add-on or OneDrive for such storage, all my stuff's local).
But just wanted to make sure you knew it existed at all
I'd maybe ask the question in the add-on's thread and see if people there can help or suggest a way.
Yes
you said it might be.
I just added the functionallity few days ago and wanted to let the user know.
You have all the credit. Don't worry.
