Full Version: Restoring Skin Settings
I'm having an issue restoring skin settings on one of my devices. I successfully done this on two other devices but this last one is giving my issues.
Basically when I try to select a skin backup file, I can only select two network locations, .TBD and DaHenchmen. I cannot find anyway to access my local drives to select the save .zip file like I did on the other devices.
Has anyone else ever had this issue?
http://i.imgur.com/QcgbYR8.png
The file browse dialogs will ONLY show locations that are added to your Kodi filemanager.
So if you want your local drives to show up, open Kodi filemanager and add your local drive(s). After that the filebrowse dialogs will show the locations you added.
(2016-10-10, 17:02)marcelveldt Wrote: [ -> ]The file browse dialogs will ONLY show locations that are added to your Kodi filemanager.
Thanks I got it
