2016-10-15, 03:33
2016-10-15, 06:56
I second this request! Also if you guys need any help with images, do let me know
2016-10-16, 20:12
well we have a h265 image, but i suppose this does not get detected somehow for you..
could you provide me a mediainfo dump that I can crosscheck the detection for h265 (I do not have any h265 files here)
2016-10-18, 08:53
General
Unique ID : 199212538168153872430888067706288336252 (0x95DEF0730D20ED0783CE82A11DC7ED7C)
Complete name : /media/movie/Movies/The Answer (2016)/The Awnser 2016 x265 HEVC AAC
Format : Matroska
Format version : Version 4 / Version 2
File size : 230 MiB
Duration : 1h 22mn
Overall bit rate : 389 Kbps
Movie name : The Awnser 2016 x265 HEVC AAC
Encoded date : UTC 2016-07-15 08:50:34
Writing application : mkvmerge v9.2.0 ('Photograph') 64bit
Writing library : libebml v1.3.3 + libmatroska v1.4.4 / Lavf57.41.100
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : [email protected]@main
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1h 22mn
Bit rate : 339 Kbps
Width : 720 pixels
Height : 304 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Variable
Frame rate : 23.976 fps
Original frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.065
Stream size : 201 MiB (87%)
Writing library : x265 1.9+226-6561d8676581:[Linux][GCC 5.2.1][64 bit] 8bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rskip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=25 / scenecut=40 / rc-lookahead=20 / lookahead-slices=0 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=3 / no-limit-modes / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=2.00 / rdoq-level=0 / psy-rdoq=0.00 / no-rd-refine / signhide / deblock=0:0 / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=abr / bitrate=357 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ipratio=1.40 / pbratio=1.30
Language : English
Default : Yes
Forced : No
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 1h 22mn
Bit rate : 48.0 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 44.1 KHz
Frame rate : 43.066 fps (1024 spf)
Compression mode : Lossy
Delay relative to video : -86ms
Stream size : 28.5 MiB (12%)
Writing library : Lavc57.48.101 libfdk_aac
Language : English
Default : Yes
Forced : No
Format : Matroska
File size : 230 MiB
Duration : 1h 22mn
Video
Format : HEVC
Duration : 1h 22mn
Bit rate : 339 Kbps
Width : 720 pixels
Height : 304 pixels
Color space : YUV
Bit depth : 8 bits
Language : English
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 22mn
Language : English
Default : Yes
Forced : No
2016-10-18, 12:52
okay and what is displayed in the media files table inside tmm for such a file?
2016-10-19, 01:13
After double clicking on the movie from the list on the left, I get the movie specific window. I then click on the "media files" tab, which is where I believe you have directed me to. There, I find the following information with the video file selected:
Codec: HEVC
Container Format: Mkv
Width: 720
Height: 304
3D Format: <blank>
Codec: HEVC
Width: 720
Height: 304
3D Format: <blank>
2016-10-19, 10:22
that logo should be in the next release
2016-10-20, 00:58
Great! Could you share the cause of the issue?
2016-10-20, 08:33
the icon has the file name h265.png and we load the icon dynamically based on the detected codec's name;
