Full Version: Smart playlist filters out sex and nudity
I'm trying to create a playlist that would allow me to filter out all movies with nude/nudity and sex/sexual. The way I tried is MPAA doesn't contain (each) nudity, nude, sex, sexual. If I reverse it so it"contains" it does show all movies with that but if I switch it to "does not contain" it just shows all movies. So if it is displaying all with nudity then why can't I filter it out? I also have enabled match one or all
Not sure what you've done, might be good to post the playlist here for comments. Sounds like your rule has to just pick just one of the words to show it, but needs to get all of them correct for it to exclude. You version of Kodi, o/s skin, hardware might be useful.
