One guy (Siggi0904) on LibreELEC IRC ask me about this skin cleaning function (removing fingeprints). Like a button to lock touch input to clean the screen. After cleaning type anything to enable input. Or locking with some passcode. Nothing happens til the correct passcode was entered.
Any thoughts? Is this possible to achieve already?
not really... there's no 'lock screen' functionality in kodi.
the closest you'll get is by following these steps:
- enable the login screen (under profile settings)
- set a password for your profile
- logoff
I think I will just make simple addon which would sleep for some time and showing countdown timer. In this time input will be disabled and screen can be cleaned safely
Mhm, this could be added in skin itself
(2016-10-17, 08:58)ultraman Wrote: [ -> ]I think I will just make simple addon which would sleep for some time and showing countdown timer. In this time input will be disabled and screen can be cleaned safely
skins can't disable input, so there's no way to do it by skinning something.
going the addon way might work.. though i think it would still be possible to close the addon (by using a longpress).
not 100% sure about that though...
remember that swipe is also an action in Kodi
I'm checking this:
http://forum.kodi.tv/showthread.php?tid=...pid2043001
Disabled cancelling and now the time must pass before I get any reaction. Good enough for now.
Just need to figure out how to include two .py files in one addon and showing two images under Addons menu (one for calibration and one for cleaning). But this is another problem.
