Full Version: Picture Slideshow update from external folder
I have been trying to make a slideshow in Kodi which will automatically load on start up and play a slide show from a folder stored in a remote location.
Using some very useful work arounds in this forum I have it almost working as I need now but I have one more hurdle to overcome.
The code I have adapted from this site is as follows.
autoexec.py (to load on start up) works great
PHP Code:
import xbmc
xbmc
.executebuiltin('XBMC.RunScript("special://home/slideshow.py")'
slideshow.py
PHP Code:
import xbmc
from time import sleep
from os import listdir
minutes
picfolder
"Pictures"
l1 = []
while
1:
l2 listdir(picfolder)
 if (
l1 != l2):
xbmc.executebuiltin("ActivateWindow(Pictures,Pictures)")
xbmc.executebuiltin("Action(Play)")
l1 l2
for seconds in range(minutes 60):
sleep(1
'Pictures' links to a remote folder via FTP. This part works fine. My sources.xml file shows the ftp path to the name Pictures.
What i'snt working is the 'listdir', 'picfolder' should be a link to the folder that stores the picture so that it can check for changes. If I use something like 'C://Pictures' it works fine but because I am trying to get this information from a remote folder it keeps saying that it cannot be found. I have tried 'Pictures', 'ftp://"server address"' but still cant get it to go.
So I guess my question is how can get listdir to work with an ftp connection.
Hope you can help
the os module only supports local filesystems.
you can use the xbmcvfs module instead for access to remote filesystems.
from xbmcvfs import listdir
Thanks very much this now works.
import xbmc
minutes = 1
picfolder = "ftp://user:[email protected]:21/web/images/"
l1 = []
while 1:
l2 = listdir(picfolder)
if (l1 != l2):
   xbmc.executebuiltin("ActivateWindow(Pictures,ftp://user:[email protected]:21/web/images/)")
   l1 = l2
for seconds in range(minutes * 60):
   sleep(1)
is there a more efficient way of adding the url to the external folder. I have tried Pictures as it is listed in sources but it didn't update but the direct address works.
Hello,
I am tryin to run same script, but I am getting some errors:
[quote] Error Type: <type 'exceptions.IndentationError'>
Error Contents: ('unexpected indent', ('/storage/.kodi/userdata/autoexec.py', 3, 1, '\txbmc.executebuiltin(\'XBMC.RunScript("special://masterprofile/slideshow.py")\') \n'))
IndentationError: ('unexpected indent', ('/storage/.kodi/userdata/autoexec.py', 3, 1, \txbmc.executebuiltin(\'XBMC.RunScript("special://masterprofile/slideshow.py")\') \n'))
-->End of Python script error report<--[/quote]
I know, it has something to do with my code formating. My code looks like this:
import xbmc
minutes = 1
picfolder = "//storage/pictures/"
l1 = []
while 1:
if (l1 != l2):
  xbmc.executebuiltin("ActivateWindow(Pictures,//storage/pictures/)")
  l1 = l2
  sleep(1)
