So, to cut a long story short, the settings on my router got zapped and now the kodi box has a new ip address. However, the kodi app on my phone still looks at the old ip address. I can't see how to update this. Are there any tips, or something that I might be missing?
TIA
Kabads
(2016-10-18, 18:44)kabads Wrote: [ -> ]So, to cut a long story short, the settings on my router got zapped and now the kodi box has a new ip address. However, the kodi app on my phone still looks at the old ip address. I can't see how to update this. Are there any tips, or something that I might be missing?
TIA
Kabads
It should be simple enough what kodi app are you using & is it on Android or iPhone?
I'm guessing you are talking about Kore. Open the left menu (drawer) and tap the host in the top left corner. Then use the context menu (three vertical dots) to select "change" for the host. This should enable you to edit the host's settings.
poisdeux - thanks for the tip - when I swipe to the right, all I get is text saying "Connecting to osmc-basil (192.168.1.225)" which is the old ip address. I can't see the context menu that you mention. The three vertical dots lead to Send text to media center, Library maintenance and Toggle Fullscreen - nothingn else. There is no "change" on my android version (which I'm assuming is the latest version as it comes from google's play store).
OK - I've solved it by installing a nightly from the website, which wiped the old settings.
