2016-10-19, 06:56
Krypton beta 3 seems to have an issue playing some HLS streams. For example h t t p://open.http.mp.streamamg.com/p/2000012/playManifest/entryId/0_4tzhwpm1/format/applehttp will play normally for a few seconds and then skips back to the start. After that it continues to play until the end.
ffplay does not show the same behaviour and neither does Jarvis, so it may be a VideoPlayer issue.
Here is the relevant log section.
The skip back occurs at 05:46:01 where the debug message is "CPullupCorrection: pattern lost on diff 53955.000000, number of losses 1"
05:45:55 T:140227725195008 DEBUG: ffmpeg[7F894FBF7700]: [mpegts] DTS 0 < 536400 out of order
05:45:55 T:140227725195008 DEBUG: ffmpeg[7F894FBF7700]: [hls,applehttp] DTS 0 < 536400 out of order
05:45:55 T:140227725195008 DEBUG: CVideoPlayer::CheckContinuity - resync backward :2, prev:5960000.000000, curr:0.000000, diff:-5960000.000000
05:45:55 T:140227725195008 DEBUG: CVideoPlayer::HandleMessages - player started 1
05:45:55 T:140227725195008 DEBUG: CVideoPlayer::SetCaching - caching state 3
05:45:55 T:140227725195008 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
05:45:55 T:140227725195008 DEBUG: CVideoPlayer::SetCaching - caching state 0
05:45:55 T:140227725195008 DEBUG: VideoPlayer::Sync - Audio - pts: 116100.000000, cache: 289364.161785, totalcache: 550000.011921
05:45:55 T:140227725195008 DEBUG: VideoPlayer::Sync - Video - pts: 0.000000, cache: 50000.000000, totalcache: 100000.000000
05:45:55 T:140227780802304 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_RESYNC(-173264.161785)
05:45:55 T:140227741980416 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_RESYNC(-173264.161785)
05:45:55 T:140227780802304 DEBUG: CDVDAudio::Resume - resume audio stream
05:45:55 T:140228085962496 DEBUG: ActiveAE - start sync of audio stream
05:45:55 T:140227725195008 DEBUG: CVideoPlayer::CheckContinuity - resync backward :1, prev:5990744.444444, curr:0.000000, diff:-5990744.444444
05:45:55 T:140227725195008 DEBUG: CVideoPlayer::CheckContinuity - update correction: -6013955.555556
05:45:55 T:140228578855296 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
05:45:55 T:140228085962496 DEBUG: ActiveAE::SyncStream - average error of -22.839299, start adjusting
05:45:55 T:140228085962496 DEBUG: ActiveAE::SyncStream - average error -0.839299 below threshold of 30.000000
05:45:55 T:140227741980416 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 40000
05:45:59 T:140227725195008 DEBUG: ffmpeg[7F894FBF7700]: [mpegts] DTS 0 < 536400 out of order
05:45:59 T:140227725195008 DEBUG: ffmpeg[7F894FBF7700]: [hls,applehttp] DTS 0 < 536400 out of order
05:45:59 T:140227741980416 DEBUG: CPullupCorrection: detected pattern of length 1: 40000.00, frameduration: 40000.000000
05:46:01 T:140227741980416 DEBUG: CPullupCorrection: pattern lost on diff 53955.000000, number of losses 1
05:46:06 T:140227741980416 DEBUG: CPullupCorrection: detected pattern of length 1: 40000.00, frameduration: 40000.000000
