Full Version: 1 Series at 2 different hdd's
Hi Com,
i use tmm to manage my media files. There was a lot of chaos. After that all is fine. But i have a problem.
For reason of space i must go with the new epsiodes to another hdd. So in Tiny i have the Series Hawaii Five-0 two times. One at F:/Series 2/... with 17 episodes at 3 season folders and the other one at K:/Series 4/... with 80 Episodes in other season folders. So Tiny rename and clean all up. In Kodi i add this 2 sources and under files i see all 6 season with all of the episodes under tv shows i see only the 17 episodes from store K:/Series 4/
What now ? Is this a problem when one series is on different storages ?
Hmm...
Inside TMM you'll have to manage two same shows (since we won't merge them)
Should be working fine that way.
But i'm unsure how Kodi behaves; or how/if it merges this together.
According to some posts, it _should_ work that way.
What you might wanna try (as test):
Use the renamer to rename your show/episodes/files to some nice naming
Delete all *.nfo files (or, at least, the tvshow.nfo in all root dirs)
Remove show from Kodi library
Scan again inside Kodi.
Does it work?
