(2017-02-21, 20:35)manderlore Wrote: [ -> ]If I don’t care about 3D MVC is there any Kaby Lake box that I in any way can get 4k 10bit in 60hz with HD-Audio bitstream (preferably also with Atmos and DTS:X) from? I was going to buy the new Intel NUC but I'm confused after reading everything that I might not be able to use it for that?
All of the Kaby Lake boxes support ATMOS, DTS:X, nd 10bit, the only issue is HDR is not working at the moment on Windows w/Kodi
PS: HDR file will playback but the metadata in the HDR file will not output to your HDR TV
I'm looking for a new htpc. The beebox-s 7100 has 2 hdmi outputs, as I understood a 1.4 and a 2.0 hdmi. Is there with the 1.4 hdmi also the hd audio passthrough problems or only with the 2.0 with dp converter?
(2017-02-23, 10:34)Eisi2005 Wrote: [ -> ]I'm looking for a new htpc. The beebox-s 7100 has 2 hdmi outputs, as I understood a 1.4 and a 2.0 hdmi. Is there with the 1.4 hdmi also the hd audio passthrough problems or only with the 2.0 with dp converter?
With the HDMI 1.4 Port HD Audio should work without any issues. I asked in a german testing Blog.
http://www.technikaffe.de/anleitung-403-..._libreelec
I will get mine tomorrow or saturday. Then I can tell you more.
No issue with HDMI 1.4 on Windows 10.
Has anybody tested for the Beebox the "HDMI Firmware upgrader ver:1.61" which you find on the support page?
i could not find this hdmi firmware upgrader
(2017-02-25, 20:35)movie78 Wrote: [ -> ] (2017-02-25, 10:57)Caramba69 Wrote: [ -> ]Has anybody tested for the Beebox the "HDMI Firmware upgrader ver:1.61" which you find on the support page?
Yes!
It doesn't work for me. I get an error when I even check the current fw version.
(2017-02-26, 12:23)Caramba69 Wrote: [ -> ] (2017-02-25, 20:35)movie78 Wrote: [ -> ] (2017-02-25, 10:57)Caramba69 Wrote: [ -> ]Has anybody tested for the Beebox the "HDMI Firmware upgrader ver:1.61" which you find on the support page?
Yes!
You have to use the HDMI 2.0 port and set the resolution in Windows 10 on the max possible (4k)
(2017-02-26, 19:12)baba420 Wrote: [ -> ] (2017-02-26, 12:23)Caramba69 Wrote: [ -> ] (2017-02-25, 20:35)movie78 Wrote: [ -> ]Yes!
It still doesn't work:
Start ISP...
Current Firmware Version: N/A
ISP initialization failed!
System Reset ...Not available!
ISP failed! (1)
ISP failed! (1)
Do you know what it fixes?
(2017-02-27, 15:44)Comp1demon Wrote: [ -> ]Anyone using an i& Nuc with HDMI 2.0 or Dual HDMI (either 2 HDMI ports or HDMI + Thunderbolt to HDMI?)
Was wondering about this?
http://www.intel.com/content/www/us/en/n...i7bnh.html
Will it allow 4K, HDR and MVC 3D?
4K Yes
HDR No
MVC 3D your best option will be the AsRock Beebox S7100
(2017-02-27, 16:02)movie78 Wrote: [ -> ] (2017-02-27, 15:44)Comp1demon Wrote: [ -> ]Anyone using an i& Nuc with HDMI 2.0 or Dual HDMI (either 2 HDMI ports or HDMI + Thunderbolt to HDMI?)
4K Yes
HDR No
Curious why no HDR
Kaby Lake using edge browser, Netflix is supposed to allow HDR.
If yes, why would other HDR content not work, (such as the HDR demos - like the LG chess demo, or Amazon HDR content)?
