Full Version: Intel Kaby Lake Hardware
(2017-03-14, 15:18)deaerator Wrote: [ -> ]Yes on both
Sent from my iPhone (typie typie)
I just read your question again, so it was working 17 but not 17.1?
(2017-03-14, 15:22)movie78 Wrote: [ -> ]
I never tried the 17 just went straight to 17.1 RC.
(2017-03-14, 15:26)deaerator Wrote: [ -> ]
Check your Windows supported format
(2017-03-14, 15:42)movie78 Wrote: [ -> ]
(2017-03-14, 15:22)movie78 Wrote: [ -> ]I just read your question again, so it was working 17 but not 17.1?
Mine is set the same.
Plex app will bit stream the lossless audio but not kodi.
Can see some pictures of your Kodi Video and Audio settings?
Did you enable sync playback to display?
I do have sync playback to display option turned on.
(2017-03-14, 15:50)deaerator Wrote: [ -> ]I do have sync playback to display option turned on.
Disable it.
(2017-03-14, 15:58)movie78 Wrote: [ -> ]
Disable it.
That worked.
Thank you.
Do you know when we should expect new motherboards with the LSPCON. I don't want to pay more than 150 USD for a simple ATX motherboard. Will we really need to wait until Computex?
I own the Asrock Beebox-s 7100u, and want to know if it has CEC capability and if it does how do you get it working?
There is a new version of the HDMI 2.0 Firmware update out on Intel, v1.65
(2017-03-21, 19:17)_Spook_ Wrote: [ -> ]There is a new version of the HDMI 2.0 Firmware update out on Intel, v1.65
Release Note Info:
Quote:This update will fix the issue of high bit rate surround sound
formats (DTSHD MA*, Dolby TrueHD*)not playing with HDMI 2.0 receivers.
No fix for 3D MVC playback issue.
2 Questions:
Has anyone able to get netflix uhd working on their beebox-s7100?
For some strange reason when I connect this to my UN65KU6290F I get no picture at all. But when I put this through the receiver then the TV it works. What would be causing no picture if connected directly to TV.
(2017-03-26, 20:01)deaerator Wrote: [ -> ]2 Questions:
Netflix is not working on my Beebox-S 7200. Not with Edge browser and also not with the Windows Store app. I get a pink screen and only solution is power off with the hardware button.
(2017-03-26, 23:13)baba420 Wrote: [ -> ]
Do you actually get a picture if you connect directly to your TV?
