AWESOME! Thanks bro!
Will existing skin settings be saved or do we need to export thoese prior to upgrade?
If we are using the holiday and/or Starwars mod can we just add thoese back after upgrade?
(2017-01-01, 22:56)Ruk12345 Wrote: [ -> ]AWESOME! Thanks bro!
You always need to have a backup, is important have one.
I installed the skin and with all the steps mentioned, and it works fine, only I can not change the colors of any item (Fonts, Panel, .. etc)
I press enter and nothing happens, am I doing something wrong ?
one more thing, where can I get the extra themes ?
EDIT: never mind, I figured out the first one, in case anybody needs it, you need to install Skin Helper Service ColorPicker
Thanks alot emiralles
any way to get the artworkDownload AddOn as default search engine, when we have new movies/series
in our libraries?
(2017-01-02, 10:09)emiralles Wrote: [ -> ] (2017-01-02, 04:23)SomeoneCares Wrote: [ -> ]Hi,
Yes, have a link for it
https://drive.google.com/file/d/0B7nL1Z3...sp=sharing
Is that the same one as inthe main repo or should we update to the version you posted above?
(2017-01-02, 18:17)Ruk12345 Wrote: [ -> ] (2017-01-02, 10:09)emiralles Wrote: [ -> ] (2017-01-02, 04:23)SomeoneCares Wrote: [ -> ]Hi,
It's the same, I don't update any
Hey @
emiralles,
I'm trying to make a backup of the skin settings. When I click "Export", it tells me it was saved successfully, but it never asked me where I wanted to save the file. Is there a default location set, or did I forget to do something, or is this something that needs to be looked at? Thanks for doing this!!!
(2017-01-03, 07:03)RonnieG3 Wrote: [ -> ]Hey @emiralles,
Think it dumps the backup in the folder of the backup addon.
Is there a fix for the following issue
Thanx
