(2016-10-20, 14:03)movie78 Wrote: [ -> ]1-Media Flag Color is not working
Do you have configure it ?
(2016-10-20, 17:27)emiralles Wrote: [ -> ] (2016-10-20, 14:03)movie78 Wrote: [ -> ]1-Media Flag Color is not working
I was unable to select that Media Flag Color even though I downloaded the addon.
I haven't got any problem
Just did a fresh install and Media Flag Icons still doesn't work
movie78, because you need activate in more one place...
Skin settings, last item in the list (MY MENU*), have a few options created with this mod, you need Turn ON for show audio and subtitle flags.
Mine version is a little different, I don´t have more this version installed, sorry, but check option you find correct item there.
* My Menu is no appropriate, I think author need rename, because My Menu is one feature available in skin used customization main menu.
Just tried and again still nothing.
Is not in this place, look in skin settings -> My Menu
Image is only for you see option My Menu (last item)
There you find place for active.
Need select package + active option in my menu area
In my custom version I put option in general settings, you find one option similar in this mod too.
PS: Click in Get More for download and install addon. In krypton you need install addons for work, allways via Addon Manager, don´t extract manually in your addon folder.
I can change the name of "my menu" for "options menu" what do you think about? . Send me any suggestions
emiralles,
Additional features or Extra features or Extras.
Reading your changelog, you say Fix bugs find in official skin, please inform bugs for author fix in official version too, if possible. Remember final version for Jarvis 1.5.0 is not available yet.
I use "options menu".
I don't have notes about the bugs corrected but it's possible that melons2 knows it better than me. I change almost all files and adapted the code for future versions of kodi.
some bugs had been comented in the forum.
I write, first, a mod in Jarvis version after I decided change all code to krypton
emiralles - Any chance you can release a Jarvis version of that PVR view
Cheers
I don't think in release a Jarvis version. You can find this solution in other mods or in a new version of MQ7 (1.5.0)
I use kodi beta 3 and my mod and haven't got any problems, and my system is a familiar mediacenter, it is always on and never hang up.
My mediacenter:
RP2B + HifiBerry Digi+ + 2TB HD (VERBATIN) + 32GB SD (SAMSUNG) + OSMC + KODI KRYPTON BETA 3
Krypton unfortunately is not an option for me right now, only as a test installation.
Do you happen to know which other mod of MQ7 has that view ?
