Any of them, try manfeed's mod. I think that is a great mod for Jarvis.
Guys, any instructions on how to actually install this? I managed to download and put in my PIs download folder, but can't seem to get it to recognize this.
Install like other skin, but install from zip file
(2016-10-25, 09:05)chester0 Wrote: [ -> ]where is the link?
Really ??
1st post. Click the word 'Here' which is in a different colour to show it's a link
(2016-10-25, 09:35)black_eagle Wrote: [ -> ] (2016-10-25, 09:05)chester0 Wrote: [ -> ]where is the link?
Really ??
omg i am so blind i went through it 3 times, thanks mate.
Hi ! Download it today and try to install it. But i get a error message that the " File Structur is wrong ". I downloaded it again with same result. Waht can i do ?
(2016-10-26, 00:42)Lady Baerbel Wrote: [ -> ]Hi ! Download it today and try to install it. But i get a error message that the " File Structur is wrong ". I downloaded it again with same result. Waht can i do ?
please, your log, I never get this error.
Does not Install on Krypton Beta4.
Tested in Beta 3, no in Beta 4 sorry. more changes in final version.
In
https://kodi.tv/kodi-v17-krypton-beta-4/
You can find this :
Known problems
• Upgrading the skin you are currently using fails on Windows.
• PVR and other binary addons fail load on Windows.
• Possible video freezes on Raspberry Pi and Android.
I have actualized my system to Beta 4 and no problem. everything it's gonna be ok.
I am using it in Beta 5........no problems!
Thank you for the MOD!
I'd love to give this a try and also make the transition to Kodi Krypton (and LibreElec Beta's), but before I do would you please answer a question...
I have made some personal modifications to my MusicVisualization.xml file in 1080p, particularly under Layout #2. I'm fine to go in and copy over the existing code for Layout 2 in the new MV.xml file, assuming that will work?
While I have gotten pretty good at modding the Music screen displays on this skin (I'm all about the Music display), I haven;t figured out if i can add my own layout as a self-standing new layout. Is that a relatively easy task?
Thx
(2016-10-31, 18:52)jasn Wrote: [ -> ]I'd love to give this a try and also make the transition to Kodi Krypton (and LibreElec Beta's), but before I do would you please answer a question...
Thx
It's easy, and I can help you by mail , send me any pictures from your Layout. I always prefered a new layout than modify any existent one, but you decided about it.
(2016-10-31, 19:49)emiralles Wrote: [ -> ] (2016-10-31, 18:52)jasn Wrote: [ -> ]I'd love to give this a try and also make the transition to Kodi Krypton (and LibreElec Beta's), but before I do would you please answer a question...
Thx
Thank you emiralles. PM sent with more info. Here's what I'm hoping to add as a new screen:
