emiralles,
You might be interested in JohnyBee's DialogMusicInfo for MQ7 Krypton last version 005 beta 2 for your next update.
See here:
http://forum.kodi.tv/showthread.php?tid=306202
Added record label icon for albums
Added year for albums
Added personal user rating in addition to the star rating fetched from the internet.
Added total number of songs
Here is a screenshot from after the update:
(2017-03-21, 20:47)jasn Wrote: [ -> ]Emiralles, I cannot get the music ratings stars to work. Is there a setting I must enable?
I solved it, public in next version.
(2017-03-23, 08:49)Dave.B Wrote: [ -> ] (2017-03-22, 10:55)emiralles Wrote: [ -> ] (2017-03-21, 13:05)Dave.B Wrote: [ -> ]@emiralles
I replaced the old customOSDMusic.xml file with the new one and the manfeed lyrics button added to the settings menu alright. But for some reason after replacing the customOSDMusic.xml file the lyrics disappear and I can no longer see them (Both regular & manffed's)
I know, i need refresh the music window but.... isn't easy.
(2017-03-21, 13:05)Dave.B Wrote: [ -> ]the "OSD menu" and "next tracks" button on the sides (see picture). I tried to roll down to the older version of customOSDMusic.xml and everything was OK (except your new addition of course).
Any idea why this is happening ?
I deleted the arrows from the music screen several versions ago, for me they are not important. You can only go to the playlist, with the left arrow, when there is a lyric in screen. and M key you can access to osd menu
Ok Bro. Looking forward for you solution and next update.
Well, I think that ..... yes
Download and unzip in 1080i folder. you can choice Default Lyrics or Manfeed Lyrics in context menu ("C" Key).
https://drive.google.com/file/d/0B7nL1Z3...sp=sharing
Enjoy it.
(2017-03-23, 21:01)emiralles Wrote: [ -> ] (2017-03-23, 08:49)Dave.B Wrote: [ -> ] (2017-03-22, 10:55)emiralles Wrote: [ -> ]I know, i need refresh the music window but.... isn't easy.
Enjoy it.
This is awesome! You nailed it!
[/img]
But since the update there is something wrong with Manfeed's lyrics. The fonts are small and the lyrics doesn't work as it used too in the videolyrics v2 update. See screenshot below.
Can you check it please?
[/img]
I don't understand!!!! I don't have this problem. Do You change any?
(2017-03-23, 23:05)emiralles Wrote: [ -> ]I don't understand!!!! I don't have this problem. Do You change any?
Didn't change anything just overwrite the 4 files from your update. I will try to roll them back one by one to see what causes it.
(2017-03-23, 23:07)Dave.B Wrote: [ -> ] (2017-03-23, 23:05)emiralles Wrote: [ -> ]I don't understand!!!! I don't have this problem. Do You change any?
Well, after playing with it a little bit I know it is not the DialogContextMenu.xml nor MusicVisualisation.xml files. I replaced them from your new update and the videolyrics v2 works perfect.
It is either IncludesLyrics.xml or script-cu-lrclyrics-main.xml can't figure out which one but my guess it's the IncludesLyrics.xml.
(2017-03-21, 11:52)extremeaudio Wrote: [ -> ]I recently moved from Ace (yes thats right!) to this skin.
Now, with Ace I used to get multiple fanarts when in the movie or tv show library. Now I get just one. I haven't made any changes, the fanart source is still default fanart and my media collection is the same as earlier. How can I get it to show multiple fanart like earlier?
(2017-03-21, 12:26)extremeaudio Wrote: [ -> ]I would also like to get the flexible widgets to stop popping up. I have turned on both kiosk modes but that hasn't helped. Can anyone suggest what to do? I am using Libreelec 8.0.0 if that makes any difference.
Hello, anyone have any suggestions about the above?
New Version 1.4.0.9 in the first post
Enjoy it
(2017-03-26, 03:33)emiralles Wrote: [ -> ]New Version 1.4.0.9 in the first post
Enjoy it
emiralles
As always, thank You for all the beautiful additions and bug fixes.
If I understand correctlyanfeed change a few fonts... And consider ing your font is small... My guess would be to check there...
Enjoy it
Thanks bro for doing this!
Still sucks they hide this AWESOME skin in the forum!
emiralles, sorry to bother you with this problem.
For some reason the skin shows logo of "Bob Marley" when playing the artist "the killers".
See Screenshots.
In the first picture I caught it exactly when the logo changed from "the Killers" to "Bob Marley" so you can see the faded logo of "The Killers" In the background.
[/img]
Here's The log file:
https://paste.ubuntu.com/24233511
I approached pscout about it in his forum but he said this is not an Artist slideshow bug, but a skin related error. See here:
http://forum.kodi.tv/showthread.php?tid=124880&page=136
Appreciate you help.
