Full Version: Music Media Helper App (Tools for Concerts & Audio)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13
@MikeKL
I tested this again this morning and I do have the issue when using 150%, not when I use 125%.
The funny thing is that when I start MMH with 125%, open the Video Scraper dialog, close it but leave MMH running at Launcher, set to 150% then reload the Video Scraper dialog 150% works correctly... I guess this is why I thought I'd fixed the issue yesterday.
EDIT: Now fixed for 150% scaling
I've uploaded MMH 5.0.5 beta 1 here with the fix:
https://1drv.ms/u/s!Aqs3ia6BNDDHiXXHcKv9...e?e=XiG1F2
There were a few nested controls which I've reorganised to simplify and that's solved the issue.
@HomerJau Thanks I confirm latest beta fixes the issue Cool Cool
Music Media Helper 5.0.5 Released:
Version 5.0.5 (August 6 2021)
Changes:
Channel Volume tool: 'Target Gain' feature now works relative to Front RMS of source channels
Channel Volume tool: Improvements in dialog loading & display
Media File Manager: Folder processing is faster
Updated PDF docs
Fixes:
Channel Volume tool: Under certain situation source files were incorrectly overwritten - fixed
Check For Updates: MMH was unresponsive during version check - fixed
Resolved dialog/font scaling issue when user sets Windows text > 125%
Music Media Helper 5.0.12 Released:
Version 5.0.12 (August 25 2021)
Changes:
Channel Volume tool: Added Dynamic Range (DR) meter (files and album DR) supports FLAC, WAV, DSF, M4A (with Atmos etc), MKA and MKV files
Audio Waveform viewer now supports FLAC, WAV, DSF, M4A (with TrueHD Atmos etc), MKA and MKV files.
Audio batch tool: Added Added Dynamic Range (DR) meter (when no foobar200 DR file found)
Updated PDF docs
The new Channel Volume toll with added DR meter supporting various file formats:
For MKV files MMH uses the Default Audio Stream if there are multiple audio streams (The MMH 'Chapter Editor' can cahnge the Default Audi stream in an MKV file)
Previous release change logs not previously posted here:
Version 5.0.11 (August 22 2021)
Changes:
Channel Volume tool: Added 'User Defined Output Folder' output option - new
Channel Volume tool: Added 'Number of parallel/concurrent files processing option
Updated PDF docs
Fixes:
Remix Channel Layout tool: Fixed issue in 5.0.10 if source file in root and new User Defined Folder used
Resample tool: Fixed issue in 5.0.10 if source file in root and new User Defined Folder used
Version 5.0.10 (August 20 2021)
Changes:
Remix Channel Layout tool: Added 'User Defined Output Folder' output option - new
Remix Channel Layout tool: Added preference for Number of concurrent files to process - new
Resample tool: Added 'User Defined Output Folder' output option - new
Resample tool: Added preference for Number of concurrent files to process - new
Audio batch tool: Added option 'Check for Silent Channels' - new
Channel Volume tool: Waveform Viewer chart more minor performance and visual improvements
Added 'Number of parallel/concurrent files processing option to:
 - Remix Channel Layout tool
 - Resample tool
Updated PDF docs
Version 5.0.9 (August 18 2021)
Changes:
Channel Volume tool: Waveform Viewer chart minor performance and visual improvements
Remix Channel Layout: Now limited to 2 concurrent conversions (fixes issue with 4 concurrent & slow hard drives)
Fixes:
Remix Channel Layout: Reading a corrupt file would report a programmatic error - fixed (file now ignored & not loaded)
Version 5.0.8 (August 16 2021)
Changes:
Channel Volume tool: Added Waveform Viewer chart - new
Channel Volume tool: Now supports adding files by drag and drop from Windows File Explorer on dialog - new
Fixes:
Audio batch tool: ReplayGain not working due to change in BS1770gain tools in previous release - fixed
Chapter Editor tool: Failed to save chapters to mka file - fixed
Version 5.0.7 (August 11 2021)
Changes:
Extract Audio from MKV tool: Add new 'Refresh Grid Tags' button to force current tag data into grid columns
Updated BS1770gain tools to latest version
Fixes:
Extract Audio from MKV tool: Musicbrainz Tagging: Selecting a disc did not update grid tags - fixed
Penteo tool: Loading 'Volume tool' from Penteo tool caused Target gain control to be disabled
Version 5.0.6 (August 8 2021)
Changes:
Channel Volume tool: 'Target Gain' now includes option to use independent source channels
Updated 3rd party UI controls & MKVToolNix files
Updated PDF docs
Fixes:
Channel Volume tool: 'Target Gain' - Setting C gain > 0 did not update Target Gain - fixed
Music Media Helper 5.0.17 Released:
Version 5.0.17 (Sept 22 2021)
Changes:
Split & Rename Concerts tool: PCM audio streams in MP4 output files now supported (PCM converted to FLAC during conversion)
Extract Audio from MKV/MKA tool: PCM audio streams in MP4 & M4A output files now supported (PCM converted to FLAC during conversion)
Fixes:
Merge Video and FLAC tool: 5.0.16 shows error message in files without audio - fixed
Split & Rename Concerts tool: If output is MP4 and selected audio stream is PCM - MMH failed to convert - fixed
Previous change log:
Version 5.0.16 (Sept 21 2021)
Changes:
Merge MKV and FLAC tool: Support added for MP4 video files
Merge MKV and FLAC tool: Renamed to: Merge Video and FLAC
Fixes:
Extract Audio from MKV/MKA tool: Failed to convert a single M4A if added using drag & drop or from file dialog - fixed
Version 5.0.15 (Sept 17 2021)
Fixes:
Extract Audio from MKV/MKA tool: Failed to convert M4A to FLAC or WAV if using drag & drop or from file dialog - fixed
Changes:
Extract Audio from MKV/MKA tool: Now loads tags in output files (e.g Tags in M4A copied to FLAC during conversion)
Version 5.0.14 (Sept 15 2021)
Fixes:
MMH Installer: Failed with .NET 5 not installed error when .NET 5 was installed and .NET 4.8 was not - fixed
Changes:
Code cleanup and minor UI changes/fixes
Updated to latest MKVtoolnix and Ffmpeg 4.4 components
Version 5.0.13 (August 31 2021)
Changes:
Resample tool: Resampling to 16 bit now uses dither
Channel Volume tool: Now saves a Foobar compatible DR file on loading file by folder
Channel Volume tool: View a DR file by double clicking on the Overall DR label
Audio batch tool: Now saves a Foobar compatible DR file if one does not exist
Long time since I updated this thread with latest update info:
Music Media Helper 6.1.1 Released:
Version 6.1.1 (July 16 2022)
New:
Application Preference added to auto append Artist name to File Names in Split & Rename, Tag & Rename & Extract Audio from MKV tools
 - Example: 01. ARTIST - SONG TITLE.flac
Fixes:
New Tag Editor control: Further improvements and bug fixes
Changes:
Split & Rename & Tag & Rename tools: Change to Re-Number Files command (now works on selected rows/files on only one folder)
Split & Rename, Tag & Rename & Extract Audio from MKV tools: Changes to the way these dialogs deal with multiple selections
Split & Rename, Tag & Rename & Extract Audio from MKV tools: Added support for grid column sorting
Updated PDF docs (many changes, additions and corrections- Please read the updated Tag & Rename tool docs regarding the new Tag Editor control)
Version 6.1.0 (July 11 2022)
New:
Split & Rename tool: Dragging multiple MKV files onto grid with Output set to MP4 converts all MKV files to MP4 files
Tag & Rename tool: Now supports loading multiple folders (albums) into the grid for tagging:
- New Add Sub Folder button (recursive loading of all sub-folders under selected folder
- Updated Add Folder button now supports selection of multiple folders (CTRL-Click, SHIFT-Click for range etc)
Tag & Rename tool: Added new 'Tag & Rename' button (previously there were two buttons 'Tag Only' & 'Rename Only'
Changes:
New Tag Editor control added to Split & Rename tool, Tag & Rename tool and Extract Audio from MKV tool
The Tag Editor control enables editing of all tags including new tags:
  Disc, DiscCount, DiscTitle, Track, TrackCount, RemixedBy
Added two new skins to emulates Windows 11 (named 'WXI ...')
Fixes:
Extract Audio from MKV tool - Failed to extract from MKV with > 24hrs of media
Chapter Edit tool - Failed to load MKV with > 24hrs of media
Tag & Rename tool - Checkbox in incorrect position - fixed
Changes:
Improved UI when users set Windows display Text & Layout scaling > 100% (also now supports per monitor scaling)
Updated to latest Ffmpeg v5 (June 20) and MKVtoolnix v68.0.0 components
Updated MediaInfo to 22.06
Updated PDF docs - Please read the updated Tag & Rename tool docs regarding the new Tag Editor control
Version 6.0.9 (April 13 2022)
Fixes:
Channel Split/Merge tool: Merge view does not display all mono files - fixed
Channel Split/Merge tool: Split view gave error reading stereo files - fixed
Changes:
Updated to latest Ffmpeg v5.0.1 and MKVtoolnix v67.0.0 components
Updated to latest MediaInfo v22.03
Version 6.0.8 (April 2 2022)
Fixes:
Batch Audio Tool: DR File issue if user's Windows Region uses comma as decimal point - fixed
Previous version 6.0.7 built incorrectly
Version 6.0.7 (March 30 2022)
Fixes:
Version 6.0.6 (March 28 2022)
Changes:
Dynamic Range (DR) files: Added new preference to Append track audio stats for all album files - new
Channel Volume tool: Now saves Audio stats now saved to DR file if new preference is set - new
Batch Audio Tool: DR analysis: Audio stats now saved to DR file if new preference is set - new
  NOTE: The new Append Track Channel Stats preference is in MMH Preferences on Launcher dialog
Batch Audio Tool: Added new checkbox under DR Analysis to force recreation of DR files - new
MMH track DR calculation: MMH ignores channels with < -30db peak level (too low to impact what you hear)
Updated PDF docs
Fixes:
Channel Volume tool: Revert to old 6.0.4 version of auto gain calc
Version 6.0.5 (March 16 2022)
Changes:
Channel Volume tool: Now supports maximum 12 channels (previously 8) - new
Extract Audio from MKV/MKA/M4A tool: Improved support M4A files
Fixes:
Chapter Editor tool: Clean up UI after previous 6.0.4 update
Version 6.0.4 (March 12 2022)
Changes:
Chapter Editor tool: Add support for CUE importing to name chapters and chapter times - new
Updated PDF Docs
Fixes:
Chapter Editor failed on saving chapters in MP4 files - fixed
Version 6.0.3 (March 3 2022)
Changes:
Updated 3rd party UI controls (incl. fix for slow file dialog)
Version 6.0.2 (February 18 2022)
Fixes:
MusicBrainz lookup could fail using .NET 6 in certain circumstances - fixed
Chapter Editor tool: Cannot change Default Audio Stream if loaded MKV/MKA file does not contain chapters - fixed
Changes:
MusicBrainz search: Add new button on Album Artist text box opens browser at MusicBrainz website for manual search
NOTE: If user copies the MusicBrainz releaseID into the Album text box & clicks find MMH loads data for the release
Updated PDF Docs
Version 6.0.1 (February 16 2022)
Changes:
Updated to latest 3rd party components: MediaInfo 21.09 and MKVtoolnix v65.0.0
Extract Audio from MKV/MKA/M4A tool: Improved support for Quad M4A files
Version 6.0.0 (January 31 2022)
ANNOUNCEMENT: 31 January 2022
VERSION 6.0 Using .NET 6 is NOW Released
You must install .NET 6 before installing MMH 6
The latest MMH 5 updater will auto install .NET 6 if not already installed via the 'Check for Updates'
Or you can manually install MMH 6 by copy and pasting thiese links into your browser:
1. Download .NET 6:
https://dotnet.microsoft.com/en-us/downl...-installer
2. Download MMH 6 Installer:
https://reva.blob.core.windows.net/mmh/publish.htm
New:
Version 6.0 now runs as a 64 bit application on .NET 6 Desktop Runtime (previously .NET 5)
Changes:
Version 5.0.32 (February 11 2022)
Changes:
New Check for Updates will auto download new MMH 6
Version 5.0.31 (January 21 2022)
Changes:
Updated to Ffmpeg 5.0.0 components
Updated to latest MKVtoolnix v64.0.0 components
Version 5.0.30 (January 7 2022)
Fixes:
Join and Split Audio tool: Error running external program - fixed
Version 5.0.29 (January 2 2022)
Fixes:
Channel Volume tool: With EU regional settings DR file shows incorrect Peak values - fixed
Channel Volume tool: Loading a folder with no audio files gave error message - fixed
Changes:
Extract Audio from MKV/MKA/M4A tool: Improved support for M4A files
Updated PDF Docs
Version 5.0.28 (December 24 2021)
Fixes:
Extract Audio from MKV/MKA tool: With output set to MKA MMH would create MKV files - fixed
Changes:
Extract Audio from MKV/MKA tool: MKV and MKA output files now have chapters removed
Version 5.0.26 (December 16 2021)
Fixes:
Audio Stream selection dialog not showing 'Codec' on 4K monitor with 150% text scaling - fixed
Converting a FLAC with DTS wav to FLAC with PCM WAV failed - fixed
Changes:
Version 5.0.25 (December 6 2021)
Fixes:
Extract Audio from MKV/MKA tool: Failed converting .M4A to .MKV - fixed
Version 5.0.24 (November 19 2021)
Fixes:
Extract Audio from MKV/MKA tool: File renaming did not add extension - fixed (version 5.0.23 regression)
Updated to latest MKVtoolnix v63.0.0 components
Version 5.0.23 (November 6 2021)
Fixes:
Extract Audio from MKV/MKA tool: File renaming added extension twice - fixed
Version 5.0.22 (November 2 2021)
Changes:
Updated Ffmpeg 4.4.1 components
Version 5.0.21 (October 14 2021)
Changes:
Merge Video & FLAC files tool: Added support for additional video input files: .avi .vob .m2ts and .ts video files
Merge Video & FLAC files tool: Output format now selectable (either MKV or MP4). Previously output file type = source type
Split & Rename Concerts tool: MMH now removes chapters from split (output) MKV output files
Split & Rename Concerts tool: MMH now ensures only one default audio stream is set for output MKV files
Chapter Editor: MMH now ensures only one default audio stream is set for MKV files
Updated to latest MKVtoolnix v62.0.0 components
Version 5.0.20 (October 9 2021)
Fixes:
Channel Split & Merge tool: MMH does not save split files to a user defined Output folder - fixed
Channel Volume tool: Using Peak Limiter option could fail with some settings - fixes
Version 5.0.19 (October 8 2021)
Changes:
Channel Volume tool: Added new Peak Limiter option (Uses a Compressor to soft limit peaks) - new
MMH5 new 'Play' now uses MPVNet player program if installed. This player supports MCH Audio and Video files with playback controls
Updated PDF Docs
Version 5.0.18  (October 1 2021)
Changes:
Channel Volume tool: Added new 'Play' button to playback original source or remixed files - new
Split & Rename Concerts tool: Loading an MKV file with no chapters can now be converted to MP4
Split & Rename Concerts tool: Added support for Drag & Drop of a single MKV file from Windows File Explorer - new
Split & Rename Concerts tool: Added new 'Play' button to playback any selected file in the grid - new
Rename & Tag tool: Added support for adding files with Drag & Drop from Windows File Explorer - new
Rename & Tag tool: Added new 'Play' button to playback any selected file in the grid - new
Play List Editor tool: Added new 'Play' button to playback any selected file in playlist grid - new
Updated 3rd party UI controls (MMH File and Folder browsers now support key search)
Updated Ffmpeg 4.4 components
Updated Docs
Notes:
The new 'Play' option supports multichannel audio files (and displays video if a video file selected - mkv, mp4 etc)
and is a basic experimental feature (no play controls). A future version of MMH will add playback controls.
Fixes:
Channel Volume tool: Now supports loading of MP4 files (supports Waveform display and Playback, not editing volume
Just downloaded version 6.4.8 as Ive not used this for a few years
there seems to be a bug when using the media file manager to generate a  tracklist csv file
I have chosen options to get Audio & Video codecs and to create a tracklist csv file
when viewing the created csv file the following can been seen
for each track on an album, the artist, and the track title are whatever the first track on the abum is rather than the actual details of each track
see the following screen shot
Please let me know if you need any more info
thanks
Tim
I think the developer of this app is on vacation.
But do try with newest version available.
See the first post here in this thread on that forum.
https://www.quadraphonicquad.com/forums/...eos.22693/
will do I followed the sticky on here and assumed that 6.4.8 was the latest version
having tried latest version bug is still there
I have discovered that if I include the option add tracklist to grid the csv file is correct althougth no tracks are added to the on screen tracklisting I'm not sure whether they should have appeared inthe on screen display or not
