Does anyone else have the issue of the Youtube addon constantly asking to go through the activate procedure (typing in the code on the youtube.com/activate site)? It seems to work ok for a day or so after signing in, but then seems to drop out and ask to activate again.
(2016-10-20, 14:48)ed_davidson Wrote: [ -> ]Yes.
Has it always behaved that way?
It should ask you to put on 2 activation codes then be good. I think I had to put in 3 or 4 then it still wouldn't search. I don't really use the addon anyway.
(2016-10-20, 15:26)ed_davidson Wrote: [ -> ]It should ask you to put on 2 activation codes then be good. I think I had to put in 3 or 4 then it still wouldn't search. I don't really use the addon anyway.
Is pretty much my experience. I put the code in twice (as per the instructions) and then it works for a day or so, but then it asks me to do the same thing again.
Thanks I'll check it out.
(2016-10-20, 16:05)eetaylog Wrote: [ -> ]Actually never mind, i see that the latest 5.2.2 release has addressed this issue. I didnt realise i wasnt on the latest version
http://forum.kodi.tv/showthread.php?tid=267160
although it's a beta, I can confirm this solved my problem on 16.1. Before I ran the updated addon, I went into settings and used the new options to delete cache and others, then ran the addon. I put in my 2 activations and up and running without issues for the last few hours.
(2016-10-21, 01:19)Fail$tyle420 Wrote: [ -> ] (2016-10-20, 16:05)eetaylog Wrote: [ -> ]Actually never mind, i see that the latest 5.2.2 release has addressed this issue. I didnt realise i wasnt on the latest version
Great, thanks. Ill bear it in mind if it continues to be an issue for me
