I don't understand what a sample is.
I use a DVD, which I've bought and which has copy protection. I can't make a sample of this DVD.
Best wishes
Bernhard
We need that dvd :-) see, it's not a general issue, but one related to two specific disks.
https://www.amazon.de/G%C3%A4nsehaut-Goo...%A4nsehaut
With this DVD Box you can test it. It is not only this two disks. I have also other DVDs where this Problem exists. I'm sure other user will get the same Problem, if the release is out and many, many user are using it.
Best wishes
Bernhard
Can you fin out if it's a Windows only issue by trying a Milhouse build via usb stick? You might need two of them. I don't have windows, nowhere... just to not buy a DVD set for nothing :-)
Only one USB stick required.
- Write LE 7.90.008 image to USB stick using USB-SD Creator
- Boot into "run" mode, and copy latest Milhouse tar file into the "Update" folder
- Reboot into "run" mode to complete upgrade of USB stick
- Boot into "run" mode, now running latest Milhouse build
Note that after typing "run" the first time, it will become the default boot option for subsequent boots.
