Full Version: No video only audio
Pages: 1 2 3
I just upgraded my system to Krypton 17 beta 3. Everything seemed normal during the upgrade but I have no video only sound. It doens't matter which source I use, my screen turns black. I tried live tv (sundtek USB + tvheadend), streaming sources
Does anyone recognize this issue and more important does anyone have a solution?
All HQ video-scalers are enabled
Thanks in advance!
Ali
Without a Debug Log nobody can help you.
So sorry for the late reaction
00:08:04 T:3033102208 DEBUG: CDirectoryProvider[addons://sources/video/]: refreshing..
00:08:04 T:3033102208 DEBUG: CDirectoryProvider[addons://sources/audio/]: refreshing..
00:08:04 T:3033102208 DEBUG: CDirectoryProvider[addons://sources/executable/]: refreshing..
00:08:04 T:3033102208 DEBUG: CDirectoryProvider[addons://sources/image/]: refreshing..
00:08:04 T:2202008384 DEBUG: Thread JobWorker start, auto delete: true
00:08:04 T:3033102208 DEBUG: CDirectoryProvider[pvr://channels/radio/*?view=lastplayed]: refreshing..
00:08:04 T:2759060288 DEBUG: GetAlbumsByWhere query: SELECT albumview.* FROM albumview WHERE (((CAST(albumview.iTimesPlayed as DECIMAL(5,1)) > 0))) AND (albumview.strReleaseType = 'album')
00:08:04 T:2759060288 DEBUG: GetAlbumsByWhere - query took 2 ms
00:08:04 T:2202008384 DEBUG: CPVRDirectory::GetDirectory(pvr://channels/radio/*?view=lastplayed)
00:08:04 T:2749102912 DEBUG: RunQuery took 3 ms for 0 items query: SELECT * FROM tvshow_view WHERE watchedCount != 0 AND totalCount != watchedCount ORDER BY c00
00:08:04 T:2404928320 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
00:08:04 T:2361903936 ERROR: VAAPI::GLUnMapSurface - Error: the requested function is not implemented(20)
00:08:04 T:2361903936 ERROR: VAAPI::GLMapSurface - Error: the requested function is not implemented(20)
00:08:04 T:2361903936 ERROR: Previous line repeats 1 times.
00:08:04 T:2404928320 ERROR: Previous line repeats 2 times.
00:08:04 T:2404928320 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 1
00:08:04 T:2361903936 DEBUG: Previous line repeats 1 times.
00:08:05 T:2404928320 ERROR: Previous line repeats 1 times.
00:08:05 T:2404928320 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
00:08:05 T:2361903936 ERROR: VAAPI::GLUnMapSurface - Error: the requested function is not implemented(20)
00:08:05 T:2361903936 ERROR: VAAPI::GLMapSurface - Error: the requested function is not implemented(20)
00:08:05 T:3033102208 ERROR: Previous line repeats 1 times.
00:08:05 T:3033102208 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is Right
00:08:05 T:2361903936 ERROR: Previous line repeats 1 times.
I can't seem to find the upload button for my complete log file. So this is part of which seems to go on and on if I change channels.
Is this something you can do with?
A FULL debug log is required and please don't copy / paste it here. Use pastebin or a similar service.
Your drivers seem to be from stone age. Why don't you upgrade your system.
How can that be? I am on v17 beta 4.
sudo apt-add-repository ppa:wsnipex/vaapi
sudo apt-get update
sudo apt-get dist-upgrade
Btw. you cut your Debug Log again (!) - therefore I cannot tell exactly what version of ubuntu you are running. So post a full Debug Log <- just follow that link and we can find out.
Edit: Most likely your mesa is hopelessly outdated, too - so let's see what we will find.
I have the same Problem since Beta 3, but only with some DVD Menus (not with the Videos). I hear the Sound but no Picture. Then it is difficult to start the correct title,, if I nothing see. But the Navigation of the DVD menu works fine (I can blind select the correct title if I know which keys I have to press, for example 3 times line down).
I think it should be reproducable I have three DVDs (TV Shows) here which have this Problem for example the german Version of "Gänsehaut - die Serie" (Goosebumps) or Wickie (German Version).
if I have time I will send a debug log in the next days.
Best wishes
Bernhard
Oki - i will read your post when the Debug Log is added - if I have time the next days.
thanx in advance!
I just started from scratch. I started with kodibuntu 14.0 then dist-upgrade and now i saw:
New release '16.04.1 LTS' available.
Run 'do-release-upgrade' to upgrade to it.
So...i am doing that right now
Here is now my log
http://pastebin.com/zEMHsNcS
I have enabled debug log, then starting the DVD, I'm Hearing only Audio, but see no Picture, then stop the DVD and disabling debug log.
Best wishes
Bernhard
It would have been possible with 14.04, too - but now you will expect the next issues during your upgrade :-)
Never the less: good luck.
You would expect more issues??
Me - not sure what I will expect :-). I know that a whole lot can go wrong if update is not done properly. We will find out, let's see tomorrow.
Pages: 1 2 3
