I'm thinking to buy a Raspberry Pi 3 to use it as a media center because my Smart TV lacks many many features.
I own already a RP1 but it's slow speed drives me crazy.
So some of my questions are:
1) Does KODI UI runs smoothly on a RP3 ?
2) Does 1080p H.264 videos plays as they should without dropped frames from a USB external HDD?
3) What are the downsides you have found so far? (if any)
I have 3 Raspberry Pi 1Bs and they perform adequately with a bit of tweaking.
Have only had mine for 2 weeks now, but:
(2016-10-22, 18:08)DeckardCain Wrote: [ -> ]1) Does KODI UI runs smoothly on a RP3 ?
Yes. I am using the
Transparency! skin which is fanart-heavy and it works great.
Obviously something like Confluence (or Estuary in Krypton) will be snappier, but I have no complaints so far.
(2016-10-22, 18:08)DeckardCain Wrote: [ -> ]2) Does 1080p H.264 videos plays as they should without dropped frames from a USB external HDD?
I play mine off a NAS via ethernet (most files are 2GB-3GB) and haven't had any issues.
(2016-10-22, 18:08)DeckardCain Wrote: [ -> ]3) What are the downsides you have found so far? (if any)
x265/HEVC won't play, which is a shame - but I knew that before buying.
I'd love to be able to use my Sky Go subscription, but without MS Silverlight it's a no-go so I need to keep a laptop handy.
Netflix won't work, but a €40 Chromecast and your phone/tablet takes care of that.
I also plan to setup a dual-boot system (
LibreELEC &
Retropie) to allow me to play retro games
Sorry to hijack, but what resolution do you get with netflix/chromebox?
(2016-10-22, 23:43)nickr Wrote: [ -> ]Thanks.
no probs. Thank you guys for Kodi
(2016-10-22, 19:34)zerocool_ie Wrote: [ -> ]x265/HEVC won't play, which is a shame - but I knew that before buying.
from a quick test, my Pi3 running LibreELEC seems to handle low bit rate x265 @ 720p perfectly, but 1080p is unwatchable
(not a bit rate expert
Plays well
Format : Matroska
Format version : Version 2
File size : 428 MiB
Duration : 1 h 6 min
Overall bit rate : 905 kb/s
Encoded date : UTC 2016-02-19T18:46:16Z
Writing application : HandBrake 20160216224539-2ffd382-master 2016021801
Writing library : Lavf56.1.0 / Lavf56.1.0
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : [email protected]@Main
Codec ID : V_MPEGH/ISO/HEVC
Width : 1 278 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Writing library : x265 1.9:[Windows][GCC 4.9.0][64 bit] 8bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=240 / min-keyint=24 / scenecut=40 / rc-lookahead=15 / lookahead-slices=4 / bframes=4 / bframe-bias=0 / b-adapt=0 / ref=3 / limit-refs=3 / no-limit-modes / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=2 / psy-rd=2.00 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=crf / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ipratio=1.40 / pbratio=1.30
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : HE-AAC / LC
Codec ID : A_AAC
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz / 24.0 kHz
Frame rate : 23.438 FPS (1024 spf)
Compression mode : Lossy
Delay relative to video : -105 ms
Title : Stereo
Language : English
Default : Yes
Forced : No
Plays but unwatchable (tearing, stuttering)
Format : Matroska
Format version : Version 4 / Version 2
File size : 871 MiB
Duration : 1 h 26 min
Overall bit rate : 1 401 kb/s
Encoded date : UTC 2015-11-05 14:03:19
Writing application : mkvmerge v8.4.0 ('A better way to fly') 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Video
Format : HEVC
Format profile : Main 10@L4@Main
Bit rate : 1 209 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.024
Stream size : 752 MiB (86%)
Writing library : x265 1.7+497-975352b2c022:[Windows][GCC 5.2.0][64 bit] 10bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=23 / scenecut=40 / rc-lookahead=15 / lookahead-slices=0 / bframes=4 / bframe-bias=0 / b-adapt=0 / ref=2 / limit-refs=0 / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=0.30 / cbqpoffs=0 / crqpoffs=0 / rd=2 / psy-rd=0.50 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock=-2:-2 / sao / no-sao-non-deblock / b-pyramid / cutree / rc=2 / pass / bitrate=1208 / qcomp=0.80 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ipratio=1.10 / pbratio=1.10
Default : Yes
Forced : No
Audio
Format : AAC
Codec ID : A_AAC
Bit rate : 192 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Delay relative to video : 31 ms
Stream size : 118 MiB (14%)
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 25 min
Bit rate : 66 b/s
Count of elements : 1162
Stream size : 41.9 KiB (0%)
Language : English
Default : No
Forced : No
I've loved using the RPI3 as my main media centre since it first came out (used an RPI2 prior to that)..
Unfortunately, I've recently come across a major flaw that will mean that I'm going to have to go back to my original plan to build a REAL HTPC...
Apparently, the RPI is unable to recognize two external drives with the same label name. This has become a major problem for me as I have invested in multiple WD Mybook drives after getting frustrated with multiple issues accessing network attached drives from the pi for my KODI setup.
While I attribute the network issues to windows 10 and the drive label issues to WD, the issue has me frustrated to the point where it tips the scales in favour of a full blown HTPC which will have more solutions to this and future issues just by virtue of the fact that more things are meant to run on it.
(2016-10-24, 18:48)crutzulee Wrote: [ -> ]Apparently, the RPI is unable to recognize two external drives with the same label name. This has become a major problem for me as I have invested in multiple WD Mybook drives after getting frustrated with multiple issues accessing network attached drives from the pi for my KODI setup.
Not really a Pi specific issue. This will be linux and will affect all non-Windows Kodi platforms.
I'm sure there is a solution. I'm not an expert but I suspect you want to add entries to /etc/fstab using the UUID of the disk, rather than the label.
This sort of thing.
(2016-10-24, 18:48)crutzulee Wrote: [ -> ]I've loved using the RPI3 as my main media centre since it first came out (used an RPI2 prior to that)..
I'm fairly sure that if you unplug the drives, connect them to a windows pc and change the labels everything will work with the new labels on the pi. You can do the same thing via putty but I can't remember the commands offhand (depends on the format of the drives).
What you can't do (apologies if I've mixed your post up with someone else's) is change the labels in windows while they're connected to the pi.
Edit: all my usb drives are formatted / labelled in windows, they all mount fine in openelec or libreelec at /media/labelname.
(2016-10-24, 19:00)popcornmix Wrote: [ -> ] (2016-10-24, 18:48)crutzulee Wrote: [ -> ]Apparently, the RPI is unable to recognize two external drives with the same label name. This has become a major problem for me as I have invested in multiple WD Mybook drives after getting frustrated with multiple issues accessing network attached drives from the pi for my KODI setup.
This sort of thing.
Yeah... as I said, i know it's not the PI's fault but I think anyone that's thinking of using it as a serious HTPC should consider this drawback when making a decision. The WD Mybook drives are quite popular and with four USB ports, it's reasonable that many people will want attach multiple drives to avoid network issues.
It's a shame because some really smart people have made this an inexpesive alternative..
As above, changing a label should sort it - takes 10 seconds.
(2016-10-22, 19:34)zerocool_ie Wrote: [ -> ]I also plan to setup a dual-boot system (LibreELEC & Retropie) to allow me to play retro games
Take a look at this.
http://www.matthuisman.nz/2015/11/recalb...mages.html
I used the images there to get the dual boot of recalbox and kodi. both can be updated separately as well. Was a very easy setup.
As for RPI3 as a media center, pretty much what zerocool said. I'm running on a RPI2, and have no issues. Even with a 1080p x264 video thats 16gb in size. Just use ethernet, and adjust the video cache for Kodi, and you'll be golden. As for retrogames, RPI3 should be very good for all consoles up to the n64.
