Full Version: Confluence -- Recently Added Disapeared
Hello, I noticed that on the main menu, under movies or tv shows, I no longer see "Recently added" button. I am able to go to recently added episodes by going to tv shows, then going to the top (..), then again to the top (..), then TV shows, then recently added tv shows.
Is there a way to reset the skin, or put it so that its back on the main page of Kodi?s
Missed the first post - Customisable home submenus
Thanks, I should have saw that post. It works and I was able to change the priority for recently added on both movies and tv shows, and after rebooting its back. Smile
If you don't mind me asking, How did you change the priority? I read the post and viewed the video, but I could not find a way to get the "Recently Added" button back on the home screen.
Change the order number.
OK. I think something is off with my installation, because I don't have an option for TV Shows or Movies until I browse under Videos. I will hit up the add-on post for support.
(2017-01-19, 03:35)DugieHowsa Wrote: [ -> ]OK. I think something is off with my installation, because I don't have an option for TV Shows or Movies until I browse under Videos. I will hit up the add-on post for support.
You have exactly the same issue I had. Just read: http://forum.kodi.tv/showthread.php?tid=224512&page=9
(2017-02-02, 18:52)rafikW Wrote: [ -> ]You have exactly the same issue I had. Just read: http://forum.kodi.tv/showthread.php?tid=224512&page=9
Thanks! It was the "Flatten Hierarchy" setting.
(2017-01-04, 20:46)BobCratchett Wrote: [ -> ]It looks like 'Flatten Heirarchy' enabled on one system and not the other - make sure it's the same on both systems. Settings > Media > Videos.
Once I toggled it, I was able to get the Library Node Editor to display the proper options and I could make the necessary changes.
