Full Version: new theme media case for aon mq7
have make some new 3 theme boxes for aon mq7 for better look
How to use
Put file boxes.xbt in media folder and choose theme boxes in settings
File and screenshot below
Download boxes.xbt file for use with Skin Aeon MQ7
great work...
(2016-10-26, 04:35)defleppard Wrote: [ -> ]great work...
i make some new cases for aon mq6 and 7 any ideas are welcome if anybody need case with logo post here RoflRoflRofl
Not working on MQ7 1.5.0 using BlueTheme
Work fine, you need put boxes.xbt in media folder, in the samer folder textures.xbt, after go to settings, appearance, in skin theme select boxes.
(2016-11-06, 20:01)Wanilton Wrote: [ -> ]Work fine, you need put boxes.xbt in media folder, in the samer folder textures.xbt, after go to settings, appearance, in skin theme select boxes.
Dear Wanilton,
As you can see on screenshot below, there is no changes?
What's wrong?
http://imgur.com/a/ScClq
@arzaz, skin donĀ“t have cover in widgets, only in library, enter there and you see.
Download link doesn't work. Anyone got a link for this for me?
Me also would like to have a look, are these a one colour or is it still possible to change the colours for different media
Hello, i need new box for 4K movies... thanks
(2017-02-04, 23:45)mattyspurs76 Wrote: [ -> ]Download link doesn't work. Anyone got a link for this for me?
link update NodNod
(2016-10-26, 02:21)subzero78 Wrote: [ -> ]have make some new 3 theme boxes for aon mq7 for better look
How to use
