Full Version: Installation VU+ Solo2 + Intel NUC
Hi!
I have satellite TV (Canal Digital Sverige) and not using their original box. I'm using a VU+ Solo2 with a CA Modul instead since this is a much better box.
As a HTPC i'm using the latest Intel NUC (http://www.intel.se/content/www/se/sv/nu...tions.html) with windows 10 and Kodi.
Can i somehow connect the Solo box to the HTPC and use the Live TV/PVR funktions in Kodi?
Like what cables to use etc. etc.
All help appreciated.
Hi Swede,
you need the plugin openwebif. Ifmyou want it easy, install the vti image for the vu+.
To install the image you need the image and a usb stick in FAT32.
In kodi you must activate the vu+ addon. In the config you need the ip adress from your vu+.
Thats all
(2016-10-26, 09:55)TheSwede1970 Wrote: [ -> ]Hi!
Just install and configure Vu+ Enigma2 client on your NUC.
Plenty of posts of it in this forum section.
I have installed the plugin, configured with the correct IP adress on my Solo2 box and it just sits there saying PVR client is starting up 0%...
Note: Using Black Hole image...
