2016-10-26, 14:06
Hello Kodi community,
As the title states, after I play a 4K movie and I minimize it without pausing it so I can select and play another movie my screen gets all fuzzy and I can discern what's happening. This doesn't happen with 1080 or lower quality movies.
To be noted that I use a custom skin, not the default one, and in this skin when you minimize a movie or video it is still playing in the top right corner. In the default skin the movie keeps playing in the background.
I belive this error comes from resizing the 4k movie in that small window in the top corner. The custom skin I use is called Black Glass Nova and I only modified how the menu looks.
Did anyone encounter this and how can I:
1. Simply remove the playing window in the top right corner or
2. Where can I find the xml code so that I can change this skin to play movies in the background when minimizing?
Thanks and have a nice day.
EDIT: I have an older version not the newest one. v15 I belive.
