Full Version: Estuary skin skipping menu item movements with an airmouse
With Kodi 17 beta 5 using Estuary skin on Android
When using an airmouse on Android and you are in the Player Settings menu(1st settings menu icon), it skips the 'languages' menu option and just moves to the item above or below it.
You can eventually select the 'Language' menu item but have to wait 2-3 seconds and it's and fluent as with the rest of the menu items.
It just makes the menu movement with an airmouse feel laggy if items are skipped.
Hope a solution can be found soon as it was present since Kodi 17 Alpha 1.
