Full Version: here's a way of changing PartyMode's behaviour
i've been messing around with smartplaylists lately (here) and after finaly getting everything working, i've made a little batch file called "list" to help me replace the PartyMode.xsp file easily - all needs to be done is open a console and use it. for example:
"list rating" will make th next partymode session find all the songs which are rated with 2 stars and up.
i'm attaching my 4 *.xsp examples - you're more than welcome to create your own queries and add them to the list.
inside the zip file:
* "list" - personally i located it in my /usr/bin/ so it would run from anywhere. use "chmod +x list" to make it runnable.
* "*.xsp" - four example files made to replace the original PartyMode.xsp. should be located in the /UserData/playlists/music/ of your XBMC directory.
btw:
i'd be happy to hear of alternative ways Smile
here's some more:
all - all tracks
best - only tracks with 3 stars and up
rated - all rated tracks
notrated - all tracks which have not been rated yet
mostplayed - i think it's understood..
never - never played before
heb - only tracks in Hebrew (can be altered into any other language
eng - only english tracks (there could be a problem with languages which has same letters as in english - can be fixed by using the "doesnotcontain" rule)
